Decided to "pimp" my mini..............just because I have a little time on my hands. decided to get a couple of 12v |sequential LED strip light turn signal silicone strips. ( A poor version of the Audi ones )
Here's the rub.......tried em out by picking up initially the o/p feed from the direction indicator unit, LG/BR wire....works a treat.
Decided to fit the strip in the top of the boot lid so that when I indicated left or right as well as my rear indicators flashing then the strip would also operate along the top of the lid, independent strips, one for right one for left.
I decided to mount the strip behind the boot lip, drill 15 or so holes along the lip, waterproof the holes with clear mastic and the run the wires, there are only two, one input one ground, directly into the feed either G/R or G/W of my rear indicator bulb holders.................switch on ....Zilch !!!!
The standard indicators work fine, I used a test probe and obviously have a feed into the relevant indicator housing/junction/unit as it works a it should BUT when I try to join or touch the new sequence indicator input feed in NOTHING HAPPENS...
Is this something to do with the LED,s being too small a load ????
When I use a test bulb everthing works fine however even if I join the LED wires with the test bulb wires ONLY the test bulb and of course the vehicle's indicators work...... Appreciate a tad bit of guidance please.
It would have been perhaps easier just to buy an Audi R8 Spyder Quattro and save naffing about......
Edited by splintercat, 21 November 2017 - 04:23 PM.
