Hi all,
I have a 1986 Mini Mayfair 998cc engine, and i would like to rebuild it. Does anyone have/know where i could get a definitive list of tools i would need for this project?
Many thanks.
Posted 22 November 2017 - 09:44 PM
Hi all,
Many thanks.
Posted 22 November 2017 - 10:14 PM
to be honest your haynes manual covers what you need.
and it all depends on what needs doing
but basic imperial sockets and spanners and a couple of suitable torque wrenches. an assortment of measuring devices. and then there are some special tools. fly wheel puller, piston ring compressor. fly wheel lock. and the big sockets for the big bolts.
Posted 22 November 2017 - 10:36 PM
Posted 22 November 2017 - 10:42 PM
If you're buying sockets look for some six sided ones. They're especially useful for those highly torqued ones that are easy to round off with 12 sided sockets.
but some of the nuts are 12 pointed.
Posted 22 November 2017 - 10:44 PM
Then I'd put a 12 sided socket on those.but some of the nuts are 12 pointed.
Posted 02 December 2017 - 06:04 PM
nicked from some where
Engine rebuild tools
Posted 02 December 2017 - 10:12 PM
Posted 03 December 2017 - 11:05 AM
Probably the biggest thing that hits home when someone takes on a "restoration project" is the amount of tools required to do the job. Someone who does not have a decent range of tools and "garage equipment" will soon find themselves spending as much buying these items than what they'll do on actual parts. Also regarding the measuring items also being able to use them correctly. I can barely use a rule correctly!
Mini Technical Sections →
Problems, Questions and Technical →
Milky Oil In Rocker After Not Draining Water Before Removing HeadStarted by jezjsa , 11 Mar 2024 engine |
Speeduino EcuStarted by cooperpooper , 09 Mar 2024 electrical, engine |
Mini Now Wont StartStarted by jezjsa , 25 Feb 2024 engine |
Rough Running On Standard CoilStarted by Sweep16 , 09 Feb 2024 electrical, engine |
Duplex Timing Chain Sprockets Alignment IssueStarted by Timrobins , 22 Jan 2024 engine |
