Oil Temperature Gauge
5 replies to this topic
#1 AeroNotix
AeroNotix
  • 267 posts
Posted 23 November 2017 - 12:50 PM
Hi, 1998 MPI.
Want to preface this with I don't need the gauges, I just want them. I like the look and having some numbers to look at while driving.
After installing an oil pressure gauge I noticed that I already had an oil temperature sender in the block. I believe this is/was standard on MPIs.
My question is: where does the wiring go for that? I tried to peel back some of the sheath on the loom but didn't have much luck finding. I don't particularly want to T off the temperature sender as I did with the oil pressure sender if I can help it. One would think I could splice the original sender's wiring and add a gauge or find where the wiring goes and hopefully find a terminal I could bridge off of.
I'm kind of hoping it doesn't just go straight into the ECU.
Edited by AeroNotix, 23 November 2017 - 12:55 PM.
#2 Wiggy
Wiggy
  • 1,036 posts
Posted 23 November 2017 - 01:08 PM
Brown/Blue wire goes straight from the sender to the gauge.
#3 AeroNotix
AeroNotix
  • 267 posts
Posted 23 November 2017 - 01:52 PM
Where does it currently go, though?
#4 Steve220
Steve220
  • 4,896 posts
  • Local Club: BMC
Posted 23 November 2017 - 02:15 PM
On the MPi engine loom it goes to the connector that goes into the dash loom. There will be a 6 pin plug in the dash loom that would go to the gauge loom. It will have a black and white wire for power , black and red/white for illumination and a blue/brown which is the sensor wire from the engine.
Edited by Steve220, 23 November 2017 - 02:16 PM.
#5 AeroNotix
AeroNotix
  • 267 posts
Posted 23 November 2017 - 02:19 PM
Steve220! Awesome news. I'll be ripping my dash off as soon as I go home!
#6 Minimpi44310
Minimpi44310
  • 11 posts
Posted 21 March 2018 - 06:23 PM
Hello,
what is the normal oil temperature on the gauge when the engine is normally hot?
My gauge say 50°C/60°C !!
I think it is cold !!
what do you read on your gauge?
Thank you,
regards,
Claude
