My mini had an frontend bump years ago and is not quite square. I will eventually put it straight. Moss have a Mk1 shell on display at the moment. Anyone got some suggestions on points to measure so I can compare with my Mk3 shell?
Engine Bay, Frontend Measurements To Make It Square?
Pepys
, Nov 26 2017 03:44 PM
3 replies to this topic
Posted 26 November 2017 - 03:44 PM
Posted 26 November 2017 - 03:56 PM
your Haynes manual has the measurements. to allow you to check that it is square. and there is no saying that the one on displace will be there for long or is correct.
Posted 26 November 2017 - 04:04 PM
chapter 11.4 gives the info and the how to.
Posted 26 November 2017 - 07:15 PM
Problem I can see is that the main location for the front end is the crossmember and its location onto front subframe, if front end is out of square then either the crossmember has moved or the subframe is bent,
When fitting a new front end the fitting of the subframe is all that's needed to keep everything square.
