Got some new wheels and want to lower the rear by around 1" or 2". Can anyone identify whether I have the right set up already or whether I need new parts.
Thanks, Lewis
Posted 09 December 2017 - 04:06 PM
Posted 09 December 2017 - 05:46 PM
Yes that does have adjustable trumpets fitted. If you undo the lock nut you can then wind the threaded part into the trumpet then re tighten the lock nut. I think the ratio for the rear is 5.1 so if you shorten the trumpet 1 inch it will drop the car 5 but someone else will be able to confirm this.
Posted 13 December 2017 - 09:08 PM
