For sale my unfinished project Pickup bare metal paint work now in upoxy primer, pretty much all new panels fitted new wings inner and outer, apex panels,rear quarters and sides rust free doors,bonnet and new heritage tailgate Ive purchased all new heritage parts ,trims to complete the project parts still in boxes , the standard engine has had new seals and gaskets with new su carburettor ,alternator electronic distributor,coil plugs leads etc ,full new cooling system with alloy radiator,thermostat,water pump heater valve and all new hoses required the engine is ready to fit once painted and can be herd running , new heritage fuel tank,steel lines, sender unit and seals ,I have a full new 10 brake setup discs hubs ,callipers and cylinders,cables etc, new fuse box and solenoid, I have a new interior kit from Newton commercials ,dash trims door panels a pair of black Oe seats , original roof trim , new window seals and trims door window runners,original glass etc, set of new alloys with 10 new tyres ,mini sport arches ,standard exhaust system, I have the original loom lights, switches etc pretty sure everything things there to complete the project, 3 litres of Best quality matched original green 2k paint harder etc to finish all the hard work has been done just paint and build then show , Im selling the pup due to total lack of time and having more projects than I can handle, Im in absolutely no rush to sell so its a fixed price £8500 if you are looking at this add you know what these are worth and the value of parts alone,if you havent got the funds dont call viewing anytime thanks I will put on some update photos as soon as get the time , the front subframe is presently removed for painting and the truck is sitting primed ,due to file size I can only load 1 photo the pup is listed on pistonheads with more pictures the pup is located in Angus Scotland UK
Edited by motorsorter, 11 December 2017 - 06:09 PM.
