http://www.turbomini...p=vt&tid=419838
I knew I'd seen it before. That's my exact solution and it works perfectly.
Was going to suggest this :).
A nice downhill free flowing path.
It's the most straight forward and simple.
Posted 17 December 2017 - 01:21 PM
Posted 18 December 2017 - 02:38 PM
What's on the inside?
Not sure about over oiled transfer leaks as it'd get centrifuged away from the primary bush and seal. I'd also think they get sloshed with far more when cornering left. I've not tried it though, so just supposition.
Posted 18 December 2017 - 09:34 PM
Posted 19 December 2017 - 09:09 AM
Ethel was that to me?
Posted 19 December 2017 - 10:39 AM
Posted 19 December 2017 - 01:42 PM
As said. The crank/big end rod gets very close there so I'd aim to have the drain between the cylinder or you'll have the crank acting as a restriction as it passes by the drain.
Thanks for that, chap! I'll have a look in the upcoming weeks for the exact location. However i'm not too fussed about it being near it as the crank would actually be moving away from the drain on its throw (engine runs clockwise when viewed from the timing chain) and the drain would be under the windage tray.
Edited by Steve220, 19 December 2017 - 01:45 PM.
Posted 19 December 2017 - 06:53 PM
ive a mpi block under the bench ill have a look tomorrow.
Posted 20 December 2017 - 01:10 PM
I was just wondering how the adapter was bolted to the Mini gearbox casing.
Posted 20 December 2017 - 01:22 PM
It was discussed as a drain previously on Turbominis and a few people had leaks because of it.
Dont forget thats very hot oil coming from the turbo. At idle, there isnt going to be much centrifugal force to get it away (none at all with the clutch depressed). Anything directed in that area could flow into the little holes instead of out.
By all mean give it a go, Ive not seen it first hand but it made sense. Especially as said people moved the return and had no more leaks.
Some stuff to think about there. The heat being the worst. You could direct the flow and if the primary isn't turning neither are the other tranny gears, if they're playing a part in chucking oil at it. You make a good point that it's not straight forward - Steve's criteria in #31.
Posted 20 December 2017 - 01:24 PM
I was just wondering how the adapter was bolted to the Mini gearbox casing.What's on the inside?
Posted 08 January 2018 - 07:07 PM
Edited by coopdog, 08 January 2018 - 07:09 PM.
Posted 08 January 2018 - 09:26 PM
Posted 09 January 2018 - 08:24 PM
Strangely that's the way I've ended up going. Bought an AN10 boss for the box and having it welded on this week. My concern was that it would leak with the rover oil return.
