hi everybody can anybody help me .i have just got a new block from mini spares fully built put everything back together timing 7 deg set static timing around 6 deg,only ran engine up to temp.and found small vertical scratches up the cylinders everything was chemicly clean before we put it together.can anybody put some light on this.thankyou
My 1380
cotty
, Dec 16 2017 09:16 AM
3 replies to this topic
Posted 16 December 2017 - 09:16 AM
Posted 16 December 2017 - 09:24 AM
Can you post any pictures?
Posted 16 December 2017 - 09:37 AM
cant at mo. only seen scratches with plugs out.we even put engine lube in the cylinders before we put the head on .plugs out built up oil pressure before we tried to start it .forgot to mention idler gear end float 5 thou clearance.as you can tell im **** at typing
Edited by cotty, 16 December 2017 - 10:20 AM.
Posted 16 December 2017 - 12:52 PM
ask minispares, they built it!
