Cooling Fan Runs All The Time?
Posted 21 December 2017 - 08:20 PM
My MPI Coopers cooling fan has started to run all the time. Are there any common faults that cause this?
Posted 21 December 2017 - 08:33 PM
This is often a symptom of a faulty coolant temperature sensor circuit (sensor and its wiring), but not limited to.
Posted 21 December 2017 - 08:35 PM
Can be damaged wiring due to age or faulty sensor
FS
Posted 25 January 2018 - 06:31 PM
Might be worth replacing the ' temperature water transducer mpi brown sensor', though a similar problem on mine was cured by removing said sensor, spraying with wd40, quick wipedown and refit.
Posted 01 February 2018 - 08:42 PM
Posted 20 February 2018 - 06:57 PM
I had the same issue on my mpi, new coolant sensor and all good now. But yes try clean it with electrical points cleaner first.
Posted 10 August 2019 - 10:21 PM
of course, this answer its not usefull to you after almost 2 years, but it may help others.
Clean the electric contacts on the sensor. You can find it very close to the expansion tank.
Edited by rolf, 10 August 2019 - 10:26 PM.
