Restoration Dilemma - John Cooper Si
Posted 23 December 2017 - 01:17 PM
The car has some tin worm around the scuttle by the front screen as well as at the seams under the headlights.
To repair and let in new metal is probably more hassle and work, particularly around the headlight and parts are so cheap it makes sense to just put a new front to save repairing the metal work in half a dozen different spots (and I cant guarantee its not worse than that). I also quite fancy taking it off, having it welded up and hanging a complete front on the wall 😃
My question is... should I have my guy - who is a fantastic metal worker - deseam the front end and lead fill like I had on my old mini. See pics. The car is a beauty and incredibly well specd. Do people think that I should stick to original seams or would deseaming alter it from original, both value and sense of how they were built.
I just think that it gives clean lines and if done well, add to longevity and rust prevention.
Answers on a postcard. 94798CBD-B875-41AE-848D-035F87DA40FD.jpeg 40.25K 6 downloads 066DC323-EE36-4079-8B0E-CE3B8E5E2794.jpeg 43.82K 6 downloads 8EE02A82-A16A-4540-B049-5358B785A57F.jpeg 69K 7 downloads 3B371DF1-E44A-486B-B748-353A19234417.jpeg 47.03K 10 downloads
Posted 23 December 2017 - 01:21 PM
Keep it standard.It will look original and hold its value
Posted 23 December 2017 - 01:23 PM
Posted 23 December 2017 - 01:45 PM
Im not a fan of the scuttle/wing loading, I dont mind the front but I would prefer the seems.
I just had a call with my guy and am pretty certain I will steer clear of seam welding the front scuttle.
The front wing is less noticeable but probably more practical in terms of keeping the water out and ensuring it’s done once and once only.
Posted 23 December 2017 - 04:38 PM
Basically it reduces the value by the cost of putting it back to original.
I once had to RE-seam a 1967 Cooper and it was a lot of work.
Posted 23 December 2017 - 04:56 PM
Posted 23 December 2017 - 05:19 PM
I respective of the potential to de-value and make the car less sell-able long term, I like the look of the standard seams I think they are a big part of the Mini's character.
Posted 23 December 2017 - 06:12 PM
Posted 23 December 2017 - 06:13 PM
Unless you really want to spend the money I'd leave it as is.
Posted 23 December 2017 - 06:49 PM
What is the main cause of the seams popping around the headlights. Is it simply down to people not drying the car when putting it away? Are there ways to help prevent recurring it without deseaming it?
Im hearing peoples thoughts and the more I consider, standard is the way to go.
Posted 23 December 2017 - 07:45 PM
Posted 23 December 2017 - 08:49 PM
"Fitted from late 1992 and on all MPI cars 1996 on it has an extra lip to give a neater seal line to help quieten down windscreen/panel vibration noise on the "drive by" homologation tests.
Also designed to help stop windscreens from leaking this seal does hold water under the extra lip causing rust on the windscreen scuttle/bodywork aperture if the rubber is perishing or going hard through weather exposure--to save rust problems many owners fit the earlier screen rubber-see CZH1719MS."
https://www.minispar...CCB10011MS.aspx
Edited by mab01uk, 23 December 2017 - 08:51 PM.
Posted 24 December 2017 - 02:24 PM
The seam below the headlights tends to rust from the inside out, from within the wheelarch - so the best way to stop rust there is to use something like Bilt Hamber UC in the arches. If putting on new wings then use a good seam sealer at the appropriate time, then once painted apply the Bilt Hamber and potentially think about arch liners.
Posted 27 December 2017 - 07:12 PM
I think I mentioned but Im having the old front welded up and it will sit nicely in the garage as a bit of wall art. All I need now are a couple of old headlights and trim rings and Ill wire up a couple of small Edison bulbs in them so I can connect it to the mains and use it as a light feature.
Ill update with progress as it comes together. Am sticking with traditional seams. None of my cars are garage queens, but I do try and use them in fair weather. I keep the car indoors under cover anyway so it should last a lifetime like that.
75FCF166-447F-4524-9008-462B1458A93C.jpeg 91.05K 2 downloads C34A2422-A452-40AB-987C-449C9F417DC9.jpeg 78.32K 2 downloads DFA358E3-7E09-4555-9220-5272DD4458DE.jpeg 69.57K 1 downloads
Posted 30 December 2017 - 07:27 PM
Going to the body shop during the week to clean and degrease the engine whilst access is good. My guy has to let in some new metal where its rotten but once that is done and the front is cleaned up, the new front should go on pretty quick.
Might as well use this as a rolling resto thread. Seems Im in it for the long haul (yet again having done the same to my Porsche last year).
AC685913-79D7-47A1-B24A-E82075A7E7CB.jpeg 57.05K 3 downloads 8944CA6A-7C45-41A0-8878-E520B9D99044.jpeg 39.06K 3 downloads 14F1F218-FC23-46A0-819E-15D786C1CEF1.jpeg 29.62K 3 downloads 1C19DFAF-8B6A-46E5-B4BC-586AAB0AAF8A.jpeg 21.4K 1 downloads
