Help Diagnose A Noisy Clutch
5 replies to this topic
#1 Lennyliverpool
Lennyliverpool
  • 329 posts
  • Local Club: northampton
Posted 27 December 2017 - 11:54 AM
Morning
I have a 1990 Mayfair which has developed a slight fault
Recently it had a new flywheel installed over another issue by my normal mini garage - and had been running great
At the time it was noted that the brake cylinder had developed a slight leak - might this be the issue?
Basically over the past few days the clutch when pressed in and out has a very faint (whirling/whining?) sound
it is very faint - you have to the radio off lol
It has no other issues - clutch works fine no slips etc
The noise is there in all gears
It has clutch fluid in it
Any ideas?
Lenny
#2 Paddi
Paddi
    Starting My Mini Up
  • 4 posts
Posted 27 December 2017 - 12:18 PM
That's usually indicative of a worn thrust race (also referred to as a release bearing). Was it renewed when the new flywheel was fitted? Most sensible garages would recommend replacing the clutch, including the thrust race when replacing the flywheel. The parts are not expensive. No need to panic, just monitor the noise and plan to replace the bearing and clutch when the noise becomes louder.
Edited by Paddi, 27 December 2017 - 12:21 PM.
#3 cal844
cal844
  • 9,485 posts
  • Local Club: TFMOC
Posted 27 December 2017 - 02:46 PM
Worn thrust bearing, was it changed(comes as a clutch kit, which is advise fitting, along with the primary gear oil seal)
#4 Lennyliverpool
Lennyliverpool
  • 329 posts
Posted 27 December 2017 - 03:13 PM
Thanks for the replies so far
The clutch itself was not changed at the time - just the starter motor and flywheel plus associated parts
Garage is open again in the new year so will clarify then
If it is the trust bearings how much of a job from a labour point of view is it?
#5 cal844
cal844
  • 9,485 posts
  • Local Club: TFMOC
Posted 27 December 2017 - 03:48 PM
Should be under £100 for a clutch kit
Then maybe 2 hours max labour(including test drive)
#6 slidehammer
slidehammer
  • 1,081 posts
  • Local Club: LSMOC
Posted 27 December 2017 - 04:22 PM
If the noise is that faint and you didn't pay for a new clutch anyway I would leave it and keep your eye (or ear) on it. Go to the garage if it gets worse. I have fitted brand new clutch release bearings and they have had a slight noise on them straight away, it will probably last for years under normal use..
