I've got a set of quad carbs from a Suzuki Bandit 250, I have seen dual bike carb swaps done before on a five port head, but what about keeping the bank of four carbs, making up a custom manifold and running two carbs for each intake port on the five port head? the engine is a 1330 with a ported/polished head.
5 replies to this topic
Posted 28 December 2017 - 08:08 AM
Posted 28 December 2017 - 10:35 AM
A lot of fiddling about for what will undoubtedly be little or no gain.
Other than the physical fitment youll likely struggle to get tuning parts to get them to fuel correctly (Ive got the more common Bandit 600 and it was difficult enough getting parts to change the fuelling on that).
So Im sure youre just looking at it as a fun engineering challenge, but Id suggest you sell the carbs and use the cash for more Mini based parts instead.
Posted 28 December 2017 - 06:12 PM
2 carbs 2 ports simple
Posted 29 December 2017 - 01:45 AM
Also, if the carbs are off a 250cc engine and the bike engine produces 40-45hp they might not be worth using on a 1330cc mini engine.
Posted 29 December 2017 - 10:31 AM
there are some new mikunis that do the job
go to an ausmini forum site and search mikuni hsr ( not off 250) not mine so kudos to the original poster over there.
Posted 30 December 2017 - 12:22 AM
Thanks for the replys, will stick with SU carbs for now then
Mini Technical Sections →
Problems, Questions and Technical →
Piston Rings - A-Series 998 Engine - Help RequiredStarted by WanaGo , 18 Apr 2024 engine |
Exhaust Choice 45Dcoe - Rc40?Started by lachlan1275gt , 13 Apr 2024 engine |
1071 Main Bearing Caps.Started by 246jaenick , 02 Apr 2024 engine |
Misfire - Ignition Fault Or Fuel Problem?Started by derekaka2sheds , 01 Apr 2024 electrical, engine |
Which Rocker ArmsStarted by mark the diver , 30 Mar 2024 engine |
