how much can you port a standard 12g940 cooper s 1275 head I want the biggest valves possible the valves are very close together at the moment don't have photos can anyone help? would it be better too port cooper s head than normal 1275 head?
4 replies to this topic
Posted 31 December 2017 - 09:33 PM
Posted 31 December 2017 - 11:00 PM
The castings are the "same" and can be ported to the same specs (early S heads excepted) but a standard S head with correct markings etc would be worth more if left untouched.
Valve sizes depend on what the cam/use will be and if you are looking at unleaded seats or not.
Edited by nicklouse, 31 December 2017 - 11:01 PM.
Posted 01 January 2018 - 02:34 AM
There's no advantage to porting the S head, any 940 can be ported just the same. Personally i'd start with a standard 33/29mm valved head, that way you've got as much material as possible to work with to allow the throats especially to be shaped effectively.
Phil.
Phil.
Posted 01 January 2018 - 10:09 AM
The best way to port a Head especially the mini ones, is to send it to someone like Phil^^^ with some cash.
Posted 01 January 2018 - 02:50 PM
Listen to Phils advice.
Fitting the biggest valves posibble in a head destined for road use, is recipe for the shortest service life from the head. Limit valve sizes to 35.7mm intake and 29.4mm exhausts.
Ac
Ac
Mini Technical Sections →
Problems, Questions and Technical →
Milky Oil In Rocker After Not Draining Water Before Removing HeadStarted by jezjsa , 11 Mar 2024 engine |
Speeduino EcuStarted by cooperpooper , 09 Mar 2024 electrical, engine |
Mini Now Wont StartStarted by jezjsa , 25 Feb 2024 engine |
Rough Running On Standard CoilStarted by Sweep16 , 09 Feb 2024 electrical, engine |
Duplex Timing Chain Sprockets Alignment IssueStarted by Timrobins , 22 Jan 2024 engine |
