6232 Crank
Decwhiteoak95
, Jan 03 2018 08:45 PM
2 replies to this topic
Posted 03 January 2018 - 08:45 PM
Hi there,
Just looking for some advice are all 1275 6232 cranks the same? Ive just got a new crank for my engine and its come from an mpi engine, the only difference I can physically see is on top of the crank webs it hasnt got the corners fully cut away, basically will it still be okay to use in a 1275 A+
Thanks in advance
Thanks in advance
Posted 03 January 2018 - 09:20 PM
It seems that it will fit all 1275cc motors except the early "S" with the different size journals.
Minispares describe it as:- "The A-Plus crank has fillet-radius journals and 1.75" wide rod journals. Suitable for 1275cc Minis, Austin Americas and Mini Metros."
http://minispares.co...ic/CAM6232.aspx
Posted 03 January 2018 - 10:15 PM
If they say it suits all of those variants then it's probably fine. I'm just slightly thinking that the MPI doesn't have a distributor drive shaft running across the engine so I'd be checking that all's well in that area if you are using a distributor
