Sagging Suspension
Posted 09 January 2018 - 09:27 PM
The suspension is sagging and I've been advised I need new donuts and advised hi los. Still struggling to see if I would ever adjust them so are they necessary?
I was looking at new shocks too as they look a bit old. Can you recommend a brand. Konis were on it new but they seem really pricy. Are gaz ok. A few folks have said just leave the old shocks on if they move freely. Is that really acceptable?
Any thoughts or advice greatly appreciated.
Posted 09 January 2018 - 09:46 PM
Hi-Los allow you to set your ride height which is a big advantage. You may never change it, but it will be where you want it. Freely moving dampers won't necessarily provide any damping force. Take them off and make sure that they offer resistance to movement for their entire travel on extension. If not, they're junk.
Posted 09 January 2018 - 10:34 PM
New donuts will have the car sitting high until they "Bed jn" the hi-lo;s will allow you to set the height and adjust them as they settle in. Or you can just look like an off roader until they do settle. Dampers are a mine field of what's good and whats bad. Not necessarily anything to do with price! The Koni's are an excellent choice being one of the best around but you will pay a premium, Gaz I would say are good for the price.
Posted 09 January 2018 - 11:44 PM
Hi-Lo units can make it easier to get the cones back in as you can wind them shorter and then lengthen them to get the proper ride height.
I've got KYB gas-a-just shocks on mine with new cones from minispares and it's a nice ride
Posted 09 January 2018 - 11:58 PM
Posted 10 January 2018 - 10:11 AM
Hilos / adjustarides a godsend...if only for ease of swapping out components...
As said if the original koni dampers still functional just keep them - they're very good indeed...
Posted 10 January 2018 - 10:55 AM
I have hi-lo's with Protech shocks. I find them better than the Gaz I replaced.
Protech are better than Gaz
Posted 10 January 2018 - 11:56 AM
I'll start working on it hopefully this weekend. Any idea how long per corner for a novice? I've ordered a Leyland workshop manual and Haynes.
If I need shocks, are there specific ones for a sports pack? If I get away with the ones in. Ideal. I did wonder if they have been so compressed for so long as the suspension is so low, then will they be knackered?
I'm so excited to be a mini owner again!!
Posted 10 January 2018 - 12:32 PM
It should be noted that the Sportspack Mini was specified with a higher grade of (Koni) shock absorber by Rover than previous Minis due to the extra weight of the large 13" wheels.
Wheels & tyres - Bigger wheel fitment consideration
"The 13-inch combination is a good deal heavier in most instances than the standard set-up so up-rated dampers are an absolute must."
https://www.calverst...-consideration/
Edited by mab01uk, 10 January 2018 - 12:36 PM.
Posted 10 January 2018 - 12:34 PM
Now you've started working on it you're going to end up buying parts. One of the best bits of advice I can give you is to become a TMF+ member. It only costs £5 and among other things it entitles you to various discounts from our supporting suppliers including 7.5% off Minispares. More importantly it also supports the forum as well.
Posted 10 January 2018 - 12:58 PM
Posted 10 January 2018 - 01:39 PM
Posted 10 January 2018 - 02:45 PM
Changing cone,damper, ball joint can be done with practice in about half an hour....but set aside the whole day to sort the front if it's your first time... And heave a huge sigh of relief when you come to the back....an hour all in should sort it...
....but... That supposes everything comes apart as it should.....
Posted 10 January 2018 - 09:50 PM
Posted 11 January 2018 - 06:44 AM
Use the money you save doing it yourself on quality parts................
