Works Lamp Bar - Recommendations Pl ?
2 replies to this topic
#1 Matt Brighton
Matt Brighton
  • 333 posts
Posted 09 January 2018 - 11:02 PM
Hi
I have had x4 lovely Lucas spot/driving lamps on my garage shelf awaiting to be installed for over a year now ..
Just bought a nice  replica  WFT567 rear boot mounted reversing light so am considering fitting the lot soon .
 looking at the available  stainless/chrome x4 spotlight works lamp bar for the front ones and suppliers prices vary from about £50 to over £100... (Mini Sport v  Mini Spares)
Is the extra worth it ?  and what would it be paying for
Can you suggest any other suppliers/options please
Thanks v much for any advice and experience with the available options,,,
Best
Matt - Brighton
Edited by Matt Brighton, 09 January 2018 - 11:03 PM.
#2 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 10 January 2018 - 12:26 PM
I went with the minisport stainless version.  https://www.minispor...abs_description
I have them fitted with lamp steadies and I am happy with them.  The mini spares version seems to use brackets which bolt through the grill, I wanted to avoid that.
Even minister sell 2 different types, the one i linked above and the same one as minispares (where the brackets bolt through the grill).
I have always found when mounting auxiliary spots/fogs, i have alway shad to use lamp steadies to keep the lamps from vibrating too much.
I also drilled new holes for the outer lamps as they would not fit with overriders in the original position. I also wanted the lamps to be closer together.
#3 Matt Brighton
Matt Brighton
  • 333 posts
Posted 10 January 2018 - 05:23 PM
Tak  Craig
Hejda !
Matt
