Hi looking for a bit of help
I have am in the process of rebuilding my 2001 MPI after major restoration and at the stage of checking the electrics after connection prior to starting. Problem I have is that the oil pressure light is not coming on when key is at position II. Have checked the bulb as changed it with the battery charge light which does come on. I have cranked the car over but have not started the car and I have oil flow up the engine. Also should my temp and fuel gauge move when I turn the ignition to position II, they currently do not, fuel gauge may not as I have not put fuel in it yet. All other electrics lights, indicators etc appear to be working fine.
Kevin
