Gear Rod And Gear Stick
9 replies to this topic
#1 minimotion
minimotion
  • 196 posts
Posted 14 January 2018 - 08:15 PM
Is there anything that should be looked at means the car is undergoing a full rebuild such as seals or springs? As from previous I have encountered spring and ball under my Morris minor gearstick many thanks
#2 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 14 January 2018 - 09:02 PM
Is it a rod change or remote type ?
#3 minimotion
minimotion
  • 196 posts
Posted 14 January 2018 - 10:01 PM
Rod change
#4 nicklouse
  • 17,935 posts
Posted 14 January 2018 - 10:04 PM
then the rod seal and then wear in the remote box where the stick goes in.
#5 mab01uk
mab01uk
  • 11,795 posts
Posted 14 January 2018 - 10:26 PM
GEARBOX ROD CHANGE ANTI OIL LEAK SEAL KIT:-
https://www.minispar...ic/MSSK050.aspx
Edited by mab01uk, 14 January 2018 - 10:26 PM.
#6 minimotion
minimotion
  • 196 posts
Posted 14 January 2018 - 10:28 PM
Where the gearstick locates onto the ball noticed a load of bolts around that section of the unit am I alright to removed all these to disassemble and clean everything?
#7 nicklouse
  • 17,935 posts
Posted 14 January 2018 - 10:47 PM
 no idea where you are now. have a look at your manual as most of this is covered in them.
or include images so we actually know what you are on about.
but to answer your question sure as long as you are aware of what might jump out and know how to reassemble it.
even looking at the minispares web site will give you a clue
http://www.minispare...ism.aspx?1~4~44
Edited by nicklouse, 14 January 2018 - 10:48 PM.
#8 minimotion
minimotion
  • 196 posts
Posted 14 January 2018 - 11:02 PM
In the link it's the centre item with the box around it with number 8,9 and 10
Looking at on here there isn't much other than the retainer pin and steady bush but actually looking at it in real life it looks as if the housing can be dismantled
#9 nicklouse
  • 17,935 posts
Posted 14 January 2018 - 11:22 PM
yes 12 can be removed just make sure you note the orientation.
11 is held onto 1 and 6 by roll pins
4 id held in place by washers and a nut inside the housing.
#10 minimotion
minimotion
  • 196 posts
Posted 14 January 2018 - 11:35 PM
Lovely just wanted to disassemble it to clean and make sure everything is fine whilst it's out of the car many thanks
