How Long Can I Store Brake/clutch Fluid?
Posted 15 January 2018 - 07:48 AM
Its DOT4. Comma.
Posted 15 January 2018 - 08:46 AM
but the bottle will have been sealed so it will be fine.
Posted 15 January 2018 - 11:06 AM
It absorbs water from the air. It's very likely fine, but bear that in mind. Warm, dry conditions and full containers are better.
Posted 15 January 2018 - 12:28 PM
Thanks for that, the bottle had like a foil seal when new, but this has obviously been removed, but has had screw cap on it. Kept in garage above freezing temps. Just did not want to replace all the fluids with stuff no better than whats in the systems.
Cheers!
Posted 15 January 2018 - 11:26 PM
Then again, they do want to sell more product.
Personally at 3 years, I'd buy fresh and smaller quantities.
Posted 15 January 2018 - 11:33 PM
dont forget the fluid in your car is open to the atmosphere all of the time. in the closed bottle it is not. like i said it will be fine.
Posted 16 January 2018 - 08:07 AM
What cost do you put on safety? Bin it and buy a new, smaller bottle.
Posted 16 January 2018 - 09:20 AM
Edited by Swift_General, 16 January 2018 - 09:21 AM.
Posted 16 January 2018 - 09:58 AM
Thanks for that, I did get rid of the old stuff in the bottle and get some new stuff. I thought the fluid once in a brake system is also sealed from atmosphere? I cant see anywhere on my bike brake and clutch systems that I changed last night where its open - unless in the caliper or something?
Posted 16 January 2018 - 10:26 AM
No the only time it will be sealed is when you have your foot on the brake - and even then it will only be the pressurised part of the system that would be temporarily sealed. The cap to the master cylinder is vented - so no different to having fluid in an unsealed bottle. This is needed to allow air into the reservoir as the level drops when pads/shoes wear.
Posted 16 January 2018 - 01:36 PM
Posted 16 January 2018 - 01:56 PM
There is a small breather hole in the reservoir cap ...
Posted 16 January 2018 - 02:33 PM
Ah yes, forgot about that, the little plunger thing. Thats on the mini, on the bike though there is no such thing, unless it exists somewhere else on the front, rear brake and clutch systems.
Will be doing the Mini next then my other bike brake and clutch (new lines too - whoo hoo!!!!)
