Rewiring 1000 Hl
#16
Posted 24 March 2018 - 10:13 PM
#17
Posted 24 March 2018 - 10:17 PM
#18
Posted 25 March 2018 - 09:24 AM
Start at the back of the flash switch and see if you can trace a wire back to a fuse.
I doubt this would cause you a practical issue, but if your car didn't come with a fog light and you fit one now, it should technically be to current standards. Fitting it under the bumper would be too low.
#19
Posted 25 March 2018 - 01:55 PM
How would you start it with no oil pressure, therefore, no fuel pump?Can you also connect the pump to the oil pressure switch? Ive read you can but dont know how to do it. This would switch off the pump if the engine stopped but the ignition was still switched on? An idea of how to do that would be brilliant?
#20
Posted 26 March 2018 - 04:18 PM
#21
Posted 26 March 2018 - 04:34 PM
An inertia switch will be fine.
#22
Posted 09 September 2018 - 11:23 AM
Posted 09 September 2018 - 11:25 AM
Posted 09 September 2018 - 03:20 PM
Hi,
The starter needs to match the ring gear on the flywheel. Which starter did you take off?
I'm concerned about how close the battery cable terminal is to the metal part underneath the solenoid.
#25
Posted 09 September 2018 - 03:25 PM
Couple of final wiring questions. I’ve looked at the wiring diagrams in the Haynes but that doesn’t help. I have an Aldon distributor but want to know if i need a ballasted coil, I don’t think so just a standard coil. But the wiring in the car is confusing. Previous areas on here led me to believe that its the black and white and white wire that goes to the coil. A pink wire would be for the ballast resisted system. Trouble is if you look at the attached picture you will see that I have black and white, white, Pink, yellow etc. The brown ones go to the alternator and I think the blue and green is for fog lights? Theres also a white and light brown wire? Any clues would be most appreciated
Hi,
I'd use a standard coil and ignore the pink wire.
White - coil positive
White/black - coil negative and distributor
Green/blue - temperature sender
White/brown - oil pressure switch
Big plug - alternator
#26
Posted 09 September 2018 - 03:35 PM
#27
Posted 09 September 2018 - 04:01 PM
Isn’t the pink wire the horn?
Ignore that, sorry. I’ve just seen the yellow with it.
#28
Posted 09 September 2018 - 04:26 PM
Hi,
Purple for the horn, can't remember the tracer colour though...
#29
Posted 09 September 2018 - 09:19 PM
#30
Posted 09 September 2018 - 09:27 PM
Re the wiring thanks for the advice much appreciated
