I now have the sandwich plate fitted, new hoses and a new heater matrix. Had the engine running and I get hot water coming from the sandwich plate to the top of the heater matrix... but the hot water doesn’t seem to come through the matrix, as the lower hose is constantly cold.
Could this be air in the system? If so, how do I get rid of the air? Or do I need to swop the hoses around?
Help With Heater Hose Correct Setup? - Metro Engine In 1983 Mini
jezjsa
, Jan 16 2018 09:27 PM
engine
16 replies to this topic
#16
Posted 03 February 2018 - 09:14 PM
#17
Posted 04 February 2018 - 09:34 AM
Might be air,
Can you lower the heater so the hose connections are on top? Remove the hose from the sandwich plate and top up through the radiator to expel trapped air. Keep the open heater hose at least as high as where it attaches.
Also note the control valve operates the other way round to the on head valve - pull the cable for hot.
Mini Technical Sections →
Problems, Questions and Technical →
Piston Rings - A-Series 998 Engine - Help RequiredStarted by WanaGo , 18 Apr 2024 engine |
Exhaust Choice 45Dcoe - Rc40?Started by lachlan1275gt , 13 Apr 2024 engine |
1071 Main Bearing Caps.Started by 246jaenick , 02 Apr 2024 engine |
Misfire - Ignition Fault Or Fuel Problem?Started by derekaka2sheds , 01 Apr 2024 electrical, engine |
Which Rocker ArmsStarted by mark the diver , 30 Mar 2024 engine |
