Mini With Rear Seats Removed
Posted 17 January 2018 - 09:59 PM
I can put a roof rack on top and put the ladder on there.
Just don't know what I can fit in the back.
Has anyone got any pics of the standard front seats with the rear seats removed so I can see how much room there is, can't really find any decent pics on Google.
If there isn't much room I could take the front passenger and rear seats out and put the front back in when I need it.
Or should I be sad and get a different car.
Posted 18 January 2018 - 07:45 AM
You really need a Minivan, Traveller, Countryman or Clubman Estate.....
Posted 18 January 2018 - 08:55 AM
don't bother it will cost you too much and will not be reliable for your work. gat a cheap **** eurobox for work.
Posted 18 January 2018 - 10:14 AM
Buy a cheap caddy or vauxhall combo
Posted 18 January 2018 - 12:32 PM
Also Minis have very little security and often get stolen when parked up amongst modern cars......not ideal for an everyday working vehicle!
Posted 18 January 2018 - 01:23 PM
And the back of the rear seat in a saloon mini is a metal panel welded into place. So all you could do is remove the actual seats (as in the cushions) which wouldn't give you much extra space than already exists.
Posted 18 January 2018 - 02:05 PM
Very bad idea for a work car.
You fancy ringing up customers saying you're broken down and can't make it today??
Will very quickly find business is quiet.
Posted 18 January 2018 - 02:35 PM
You can fit a twin turntable disco set-up, a pair of 200w speaker cabs, various disco lights, mic stands and all the boxes for 7" singles in the back where the seats would be. Ah, the heady days of the scouts & guide disco, me and my mate used to run around with the old mk1 chock full
Like has been said, I'm not sure how suitable one would be for a decorating business, it would be novel though.
Posted 18 January 2018 - 11:00 PM
Best to but a cheap modern hatchback or small van for work and then save for a classic car for weekend fun.
Posted 18 January 2018 - 11:49 PM
I will probably get a vauxhall combo or something like that instead.
Minis are just too nice though. :)
Posted 19 January 2018 - 12:01 AM
Hello, thanks for all the replies, not the news I wanted to hear but very helpful. :)
They are 'nice' as 60-year-old designed iconic classic cars with old car 'retro' driving feel and reliability.
A lot of regular attention is needed and that is why they are best kept for weekend fun, classic car shows and runs.
For work you will probably need to be able to turn up on time, every time, do a days work and drive home again. Only a modern car will give you this.
Posted 19 January 2018 - 05:44 AM
Minis are just too nice though. :)They are 'nice' as 60-year-old designed iconic classic cars with old car 'retro' driving feel and reliability.
Not absolutely true Cooperman, I've been going back and forth to work and everywhere in between for the last 4 years. The mini does take a lot of attention though (much to herself's annoyance ) I'll give you that.
Posted 19 January 2018 - 09:23 AM
Same for me here!
Been very reliable as a daily for me, however you do have to keep on top of maintenance before it requires it!
I will admit that I don't do a job lumping ladders around though!
Posted 19 January 2018 - 11:24 AM
I think people are being a little harsh, Minis needn't be that unreliable, especially compared to used a van with similar potential running costs.
Still don't think it's a good idea though. The car's likely to take a bit of a battering, which isn't good if you're expecting it to hold its value, like a classic should. If it does require major work, you probably won't want to just let it go and get a replacement, that's how you're more likely to be stuck getting to jobs . It'll also cost you a lot more than a true bangernomics strategy.
If you're absolutely intent on doing it, removing the front seat and knocking up a storage bin to replace it could be a good way. No more work than stripping the back out.
Posted 19 January 2018 - 11:58 AM
If you were absolutely determined you could make the car reliable enough if you put some work into it. Check every wire and connector and if there's loads of stuff spliced into the loom, replace it, so you know all the connections are good. Check all your earths, possibly swap the earths so they're wired directly to the battery rather than relying on the body. Fit a Megajolt system to get rid of the distributor, points and coil.
If all the mechanics start off in tip-top order and you keep on top of maintenance then it should be fairly reliable. But really what you need is to understand how everything on the car works to be able to spot where it might fail and fix it before it does.
That said, unless your daily drive is garage to garage or secure car park at worst, it's not worth the risk I don't think. Also bear in mind that rush hour traffic is full of idiots half asleep, on their phones or eating cornflakes, and they won't be looking where your Mini is.
