Rover Coupe Seats
Posted 18 January 2018 - 07:33 PM
Ive read through the respective thread for which seats fit a mini but Im after a little more detail regarding the subframe side of things.
Thanks in advance,
Luke
Posted 19 January 2018 - 09:37 AM
Edited by Steve220, 19 January 2018 - 09:37 AM.
Posted 19 January 2018 - 07:06 PM
Never attempted welding in my life. Something I like the idea of trying at some point but as it stands. No gear and certainly no idea.
Posted 23 January 2018 - 01:12 PM
Posted 23 January 2018 - 01:41 PM
Hi,
If you're not experienced and you're going to try welding for the first time, I would suggest something as safety critical as a seat subframe is not the best place to start.
Posted 24 January 2018 - 10:09 PM
It might just be case of entrusting a decent local garage to fabricate something for me.
Posted 25 January 2018 - 01:50 AM
Reason I ask is i've seen these fitted to a few minis in the past and all have said that a bit of fabrication is required.
Posted 25 January 2018 - 01:51 AM
Posted 25 January 2018 - 03:09 AM
Hi, any advice on fitting Rover Coupe seats to a mini? Im changing my buckets to 200 Coupe seats as theyre more suitable/child seat friendly. Any advice, recommendations or contacts for the seat subframe mods thatll be required?
Thanks in advance,
Luke
Basically you need to weld in rear surports. You can do this many different ways Ive seen
A 2nd crossmember welding in place.
A bar/box section welded across
Box towers welded to the floor
Personally I would go for the 2nd crossmember or box section welded across the car with spredder plates welded where the box section meets the floor.
All is quite a simple job for a good welder/fabricator
Also you will need to weld/fabricate a fixings to the front crossmember plus modify the seat runners too if memory serves me right.
Hope this helps
Posted 05 February 2018 - 11:14 PM
Hi There,
My solution might not be good for you as my Coupe seats don't tilt directly (they are on universal subframes attached to the floor) however the way the seats are attached to the subframes suggests that they could be bolted to a proper mini tailored subframe. Of course the backrest tilts forward so if you kids are reasonably small/athletic they would probably still be able to get in the back although my subframes are also bolted behind the crossmember to give more legroom up front so there wouldn't be much in the rear with the way mine are done
Basically most of the gubbins underneath the seat is cut away but leaving a vertical part of the frame to which is bolted a right angle iron to give a flat surface to bolt the subframe to (tailored or otherwise)
The gubbins is cut at a bit of an angle to give the seat base some rake - probably would be nicer with a bit more but there is only a limited amount of metal frame left.
In theory I could play with the subframes to get more rake if needed though which I guess you couldn't do on a tailored version (are they raked as supplied?)
Unfortunatley I don't have any pictures - this was done when I got the seats (the guy had them on tailored - I happen to use universal to the floor to keep them lower)
Regs
Posted 18 March 2018 - 04:53 PM
Posted 27 March 2018 - 10:28 AM
Good thread - will be keeping an eye on it as I've got a pair of Tomcat coupe seats that I'm toying with using too, for similar reasons :)
