Silly Hornet Question
Posted 21 January 2018 - 07:59 AM
Posted 21 January 2018 - 09:30 AM
Hi, if it the same as my MK2 Mini the switches do the following. Steering stalk - indicators and headlight flash when pulled back and horn when pushed in. Switches either side of the ignition switch - one is headlights and side lights (the 2 position one) the other is single speed windscreen wipers with self park. The other switches have been added for accessories. I would think you are better getting the correct loom from the start or carefully repairing yours using either a wiring diagram on here or in the Haynes Manual. There are so many differences in the later type looms that I think you would be making more work for yourself. all the connectors would be different and the later loom would have 2 steering wheel stalks 2 speed wipers, alternator rather than dynamo etc.
Posted 21 January 2018 - 09:50 AM
