Stainless Steel Mig Weld Gas
Posted 02 February 2018 - 11:38 AM
Posted 02 February 2018 - 11:56 AM
top tip.
have a totally separate welder and tools for welding stainless or you will find it will rust.
Posted 02 February 2018 - 12:44 PM
How much and what are you welding? If its any help, I welded a cat back for my mx5 from mostly stainless pipes and just normal mild 1.0mm wire and argonshield gas (works welder!), then gave the joints a coat of bbq paint to stop them rusting
Posted 02 February 2018 - 02:03 PM
Yep, its just for one job. Inlet manifold for my supercharger. So buying a load of equipment isn't an option. I prefer to use my existing MIG. Is the Argonshield pure Argon
Posted 02 February 2018 - 02:25 PM
to be honest I would farm it out.
people who weld both keep two separate systems as the stainless picks up carbon from the welder and you then get rust appearing. if you are not bothered about rust then I would just use normal wire it will weld fine. done it many a time.
Posted 02 February 2018 - 03:36 PM
Posted 02 February 2018 - 04:13 PM
What gas did you useto be honest I would farm it out.Yep, its just for one job. Inlet manifold for my supercharger. So buying a load of equipment isn't an option. I prefer to use my existing MIG. Is the Argonshield pure Argon
Posted 02 February 2018 - 05:33 PM
whatever was in the Mig at the time as it was not going to be a stainless weld.
like i said putting stainless wire in your mig and changing the gas will result in welds that could and most likely will go rusty.
Posted 02 February 2018 - 07:30 PM
Posted 02 February 2018 - 08:00 PM
have a chat with Matt and see what he recommends.
it may be ok. all that i know is people who make a living from it would not.
Posted 02 February 2018 - 08:18 PM
really you need to change the liner for a fresh one and clean the feed wheels and torch and fir a fresh tip, gas wise you really need argon with 3-5%co2, ranther than the normal argo sheild or co2, also pure argon dosent work as well,
another thing is stainless often expands and contracts a lot when welding, when I did my first turbo exhaust it shrank a good 5+mm and I had to scut and extend it... PITA! the key is plenty of tacks and then do short sectionsand move around to other sections
of course if ypou get Matt at fusion to do it he wil tig it, which is another ballgame
Edited by mini13, 02 February 2018 - 08:19 PM.
