1997 Mpi Mini Project - Backdate
23 replies to this topic
#1 rich_959
rich_959
  • Just Joined
  • 568 posts
Posted 02 February 2018 - 01:23 PM
I thought I might start a thread on my project as a bit of a record for myself, and also to probably ask some questions as we go along.
It's a 97 standard mini which had been given an aftermarket Sportpack. I wanted an SPI or MPI car, mainly because I wanted the reliability of electronic ignition etc. It took a while to find a relatively solid one that was a reasonable price. First pic is how it looked on the day I bought it.....
The intention is to go for a Mk3 Cooper S style. If bodywork ends up meaning a bare shell, then I'll probably go for an earlier Mk1 colour, but I'm not worried about originality (it's a late car after all) I'm just doing what I want, which is part of the fun of a project I say! I've done the concours/originality thing with other cars, but this is just going to be a mini which reflects the different things I like from the whole 40 year spectrum.
So I fitted 7.5" cooper s style brakes in order to get the 10" minilite replicas on, and then began stripping the car. You can see below the stage that I'm at. It's about to go to the local garage for the engine out (hence my handy stool for driving it in and out of my garage!).
Once the engine is out, it will be going to a bodyshop in Hull for a new front end, a full paint strip, any other corrections and then respray. I'll take more photo's as things progress!
Cheers,
Rich.
Attached File  001.JPG   90.27K   9 downloads
Attached File  002.JPG   54.37K   7 downloads
Attached File  003.JPG   105.53K   5 downloads
Attached File  004.JPG   97.88K   6 downloads
Attached File  005.JPG   104.94K   7 downloads
Attached File  008.JPG   74.22K   12 downloads
Attached File  009.JPG   63.51K   12 downloads
Attached File  010.JPG   68.25K   11 downloads
#2 Archived1
Archived1
  • Archived
  • 619 posts
Posted 02 February 2018 - 03:06 PM
Little red seat is awesome!
#3 rich_959
rich_959
  • Just Joined
  • 568 posts
Posted 02 February 2018 - 03:19 PM
Ha, think its a keeper!
#4 Vinay-RS
Vinay-RS
  • 2,115 posts
Posted 02 February 2018 - 06:21 PM
Good luck on this one. Looks like a nice project and it'll definitely look good with the early retro styling.
#5 Mervyn
Mervyn
  • 256 posts
Posted 02 February 2018 - 06:57 PM
Wow it looks so much better on 10s without the sportspack on. even with the arches being chopped. Nice work
Merv
#6 rich_959
rich_959
  • Just Joined
  • 568 posts
Posted 03 February 2018 - 12:02 PM
Cheers guys. Yeah, the hi-los will need to bring it down a bit. Its got some additional spacers on the rear too which need to come off to make the wheels sit in the arch correctly.
#7 rich_959
rich_959
  • Just Joined
  • 568 posts
Posted 03 February 2018 - 12:28 PM
Engine is also now out. Bulkhead/inner wings look fairly solid, but definitely some previous repairs there. See what its like when the paint is removed.
#8 rich_959
rich_959
  • Just Joined
  • 568 posts
Posted 20 February 2018 - 03:37 PM
Small update: The body shop have made a start, removing the front panel and wings.
Looks like we'll be going for new inner wings, so it will be a full new front end from the bulkhead forwards.
Attached File  013.jpg   99.95K   4 downloads
Attached File  012.jpg   53.96K   5 downloads
Attached File  011.jpg   59.03K   5 downloads
#9 rich_959
rich_959
  • Just Joined
  • 568 posts
Posted 23 March 2018 - 06:01 PM
Dashboard built up tonight. Excuse the bedspread workbench!
Managed to finally find the fabric bit that goes round the edge, like from the factory.
#10 rich_959
rich_959
  • Just Joined
  • 568 posts
Posted 15 May 2018 - 02:49 PM
Slow going on the thread as the car has been waiting for its slot in the bodyshop.
Quick progress update on the engine and gearbox which have had a strip and rebuild with the following upgrades:
Swiftune SW5-07 cam kit
Swiftune Duplex Timing kit (steel)
MED ST1 Clutch/flywheel
Maniflow Manifold and system
Mild head polish/port and inlet and manifold matching
X Pin Diff
Central Oil pick up
And that's it! Engine is just about good to go (I'll get some pics up) so I just need the shell back now.
#11 rich_959
rich_959
  • Just Joined
  • 568 posts
Posted 07 June 2019 - 07:53 AM
I'm very slow at keeping this up to date.
Engine is finished, and I've just given it a lick of paint. Just need a body to drop it in now!
It came back from the workshop with this oil filter, which is longer than the ones I bought from Minispares. Is that a problem? I'll check with the garage.
#12 rich_959
rich_959
  • Just Joined
  • 568 posts
Posted 02 July 2019 - 10:35 AM
Front end trial fit, prior to dropping subframe and removing all paint. Good to finally see some progress on the body!
#13 Ben Rose
Ben Rose
  • 210 posts
Posted 09 August 2019 - 02:02 PM
Hope your bodywork gets done soon for you.  All looks great so far.
Where did you get the fabric bit from?  As you know we've got similar issues and a water damaged dash is one of them!!  Following your posts now.
#14 rich_959
rich_959
  • Just Joined
  • 568 posts
Posted 12 August 2019 - 07:46 AM
Hi Ben, and thanks for the comments!
The dashboard trim came from South Lakes Minis on ebay but they don't seem to be listing it anymore. Might be worth giving them a call?
#15 Ben Rose
Ben Rose
  • 210 posts
Posted 12 August 2019 - 01:45 PM
Cheers Rich!
Cheers Rich!
