+1 for head gasket.
you can whip the head off in half an hour if you're angry enough with it
Posted 06 February 2018 - 10:49 AM
+1 for head gasket.
Posted 06 February 2018 - 10:52 AM
I would agree with the others in taking the head off, you'll find its one of the easiest engines to take the head off. If you have'nt got a Haynes manual, invest in one, you'll find them on ebay at a reasonable price. Once you've got it off check both the head and the block are true with a steel rule. If you have one run a surface plate with some wet and dry over both. As Cooperman says, lap the valves and fit valve stem oil seals.
Posted 06 February 2018 - 11:40 AM
Posted 06 February 2018 - 01:32 PM
Mini Technical Sections →
Problems, Questions and Technical →
Exhaust Choice 45Dcoe - Rc40?Started by lachlan1275gt , 13 Apr 2024 engine |
1071 Main Bearing Caps.Started by 246jaenick , 02 Apr 2024 engine |
Misfire - Ignition Fault Or Fuel Problem?Started by derekaka2sheds , 01 Apr 2024 electrical, engine |
Which Rocker ArmsStarted by mark the diver , 30 Mar 2024 engine |
Milky Oil In Rocker After Not Draining Water Before Removing HeadStarted by jezjsa , 11 Mar 2024 engine |
