Sound Deadning
24 replies to this topic
#16 smithy3793
smithy3793
  • 259 posts
Posted 08 February 2018 - 04:02 PM
silent coat in mine with some closed cell foam over the top (doesn't absorb water). Doing the same in the pickup. Seems to have dampened down the bangs and clatters
After the comments regarding Silent Coat I think I will opt for this option. Can you remember how many sheets/boxes that you needed to purchase?
thanks
#17 Richie83
Richie83
  • 1,494 posts
Posted 08 February 2018 - 07:48 PM
thanks
I used a box for the floor, a couple on the roof, doors, back seats. Was plenty.
#18 mikal
mikal
  • 240 posts
Posted 08 February 2018 - 08:04 PM
The thing about using carpet underlay is you can easily remove it if you want to know what's going on underneath. My car doesn't leak but every now and then I lift it up to have a peek anyway....
#19 Richie83
Richie83
  • 1,494 posts
Posted 08 February 2018 - 08:06 PM
to be fair i've got overlay over mine too. It's better clad than my house
#20 screech
screech
  • 3,136 posts
  • Local Club: Bognor rock ya mini & WSMOC
Silent coat is the best (if not better) dynamat alternative.
Though what do you want to achieve? Dynamat type products are to stop panel resonance, they are not used to block out sound.
To block sound out you need a closed cell foam, like luxury liner pro...
#21 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,017 posts
Posted 08 February 2018 - 08:17 PM
thanks
I used nearly a one of these boxes on mine. 8 or 10 sheets on the roof, on the parcel shelf, rear seat, 1/4 panels, doors, engine bay bulkhead internal, flitches and floors.
https://www.ebay.co....=item2331949ee3
Edited by alex-95, 08 February 2018 - 08:22 PM.
#22 pusb
pusb
  • 1,216 posts
Posted 08 February 2018 - 08:47 PM
Can you put the closed cell foam stuff inside doors?
I know its not supposed to hold moisture, but is that true? There must be a lot of water that runs through the inside of the doors.
Also does it interfere with the window runners?
#23 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,781 posts
Posted 08 February 2018 - 09:05 PM
It is worth re-mentioning that the likes of silent coat, dynamat and generic black anti drum pads do not need to cover every square inch of panel work inside the car.
Their purpose is to stop drum and resonance so you only need a fairly small sheet on each quarter of the floor pan, one on the inside of each quarter panel and inside each door skin and then 2-3 on the inside of the roof.
Any more is just a waste of time and money as many of the inside surfaces of the panels are rigid especially inner sills, the toe board and bulkhead
#24 Steve220
Steve220
  • 4,896 posts
  • Local Club: BMC
Posted 09 February 2018 - 11:50 AM
You can, and it does make a difference, it's just a nightmare to get in and stick!
#25 smithy3793
smithy3793
  • 259 posts
Posted 13 February 2018 - 09:33 PM
Thanks for the recommendation for silent coat, just applied this evening and it is a great product
