Front Calliper Hose Won't Loosen
11 replies to this topic
#1 rubdub
rubdub
  • 69 posts
Posted 09 February 2018 - 05:51 PM
I've been trying all day to get my brake hoses off my front brakes on my 98 mpi but to no avail. Want to change callipers. Have been trying spanners and vice grips but no luck.
It is right/tight left/loose on them right? Any advice most appreciated!
#2 Steve220
Steve220
  • 4,877 posts
  • Local Club: RAF Mini Club
Posted 09 February 2018 - 06:11 PM
Anticlockwise. Odd that they're not coming undone! usually having the copper washers allows an easier crack.
#3 Dusky
Dusky
  • 5,322 posts
Posted 09 February 2018 - 06:22 PM
Cut Them and use a socket.
There are special brake pipe wrenches for the steel lines too. Id replace those too anyway on a car of that age.
#4 MatthewsDad
MatthewsDad
  • 720 posts
Posted 09 February 2018 - 06:27 PM
+1
#5 nicklouse
  • 17,900 posts
Posted 09 February 2018 - 08:51 PM
always easier to remove the subframe end first.
#6 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 09 February 2018 - 09:22 PM
some are chuffing tight, but good grips and tap them with a hammer works
#7 rubdub
rubdub
  • 69 posts
Posted 10 February 2018 - 08:14 AM
Yeah thats my back up plan to take off the hose completely, but Ive heard changing the front brake hoses is a pain in the ass?
Will try again today with some gentle persuasion.
#8 MatthewsDad
MatthewsDad
  • 720 posts
Posted 10 February 2018 - 09:58 AM
But I guess if the hose is that rusted up the internal condition of the rubber will be past its best too? For peace of mind and a few quid I'd be tempted to bite the bullet and replace the old hose.
#9 rubdub
rubdub
  • 69 posts
Posted 10 February 2018 - 10:10 AM
Yeah seems so. I'm literally rounding the nut now...
Any recommendations on tutorials on changing flexi hoses? Where is the best access to the bolt on the far side of the sub frame?
Cheers for the help lads!
#10 weef
weef
  • 412 posts
Posted 10 February 2018 - 07:45 PM
Don't forget you will have to tighten these hoses onto the replacement items. If they are that difficult to remove then the same applies to tighten. Bin them and buy new quality hoses.
#11 rubdub
rubdub
  • 69 posts
Posted 20 February 2018 - 07:10 PM
Ended up brining them to my local mini garage and had them changed. Front right disk/brake are rubbing now when turning corners...
#12 MiniMoe2008
MiniMoe2008
  • 163 posts
  • Local Club: None Around Here
Posted 20 February 2018 - 09:35 PM
+1
+2
