Replacement Panel Coating
Best Answer sonikk4 , 10 February 2018 - 10:28 PM
They are either Magnum panels or Heritage no matter what.
So if its a pattern panel remove the coating. If its a Heritage panel thoroughly check it for spider tracks of rust. You will still need to give it a good key before paint, so i tend to flat them right back no matter what. And that is speaking from experience here with regards to the spider tracks.
Go to the full post
1 reply to this topic
#1 Ghostrider
Ghostrider
  • 68 posts
Posted 10 February 2018 - 05:04 PM
Hi All,
So with any replacement panel for our minis, they always come with this black anti rust coating on them. I know for magnum panels this coating 100% has to be removed before painting over as it causes all sorts of problems.
However has anyone had any issues with the coating on minspares own panels, its almost like a semi gloss coating, could i just flatten it and primer over? Or is it good practice to just remove it all and then paint etc?
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 15,900 posts
  • Name: Neil
Posted 10 February 2018 - 10:28 PM   Best Answer
