Pop Riveting Mini Special Arches
Posted 16 February 2018 - 09:30 AM
My dilemma now is how to refix the wheel arch extensions using pop rivets, I had looked at using black self tapping screws but the fixing holes are far too big for this idea; so back to pop rivets. Ive 2 pop riveting tools a single hand held one and also a two arm bigger pop riveter, but both of these are too big to fit into the cut out in the wheel arch.
Can anyone recommend a pop riveter with a long narrow nose that would allow me to refix these arches?
Posted 16 February 2018 - 10:09 AM
I find a normal hand held rivetter will normally just fit. I have also previously used a short (5mm or so) piece of metal tube slipped over the rivet shank first, but it can cause the rivet shank to be too far away from the jaws inside the pliers such that they can't grip and pull it.
Other options are rivnuts in the wing then machine screws; or self tappers with spire nuts on the inside of the wing.
(if using self tappers I always file/grind the point of afterwards so I don't slice my hand open when doing any work in the area)
Posted 16 February 2018 - 10:40 AM
M4 Riv-Nuts and stainless steel socket head cap screws/washers are the very best way to fit arch extensions. They are then easy to remove, keep corrosion to a minimum and it looks a professional job.
Namrick Ltd can supply all you need and you can order on-line for very quick delivery.
Posted 16 February 2018 - 10:51 AM
Button heads look more professional
Posted 16 February 2018 - 04:38 PM
Merv
Posted 17 March 2018 - 08:04 PM
Posted 27 March 2018 - 09:58 AM
Thanks for the replies, I used some m4 button head bolts, really pleased with the results and easy to remove again if needed
Just about to do this myself, and had M4s on the list to order - using button heads is a great shout. What length did you go for?
