Hi all,
What's the best way to get the oil going around the engine after a rebuild ? MPI engine.
Thanks.
Posted 18 February 2018 - 05:30 PM
Hi all,
Thanks.
Posted 18 February 2018 - 06:03 PM
Posted 19 February 2018 - 07:33 AM
No, it's not a new engine but it has been sat for a few years. I haven't touched the oil pump.
I gave it a go last night but my battery only lasted about 10 seconds before the starter started to slow down..
Posted 19 February 2018 - 10:25 AM
Did the oil light go out?
Posted 19 February 2018 - 10:40 AM
Posted 19 February 2018 - 10:45 AM
The primary gear has been changed, the top hat bush was fubbered.
I split engine and box just to have a visual look at everything before putting it all back together.
No, the oil light didn't go out after 10 seconds of cranking, no sparkplugs in either.
Posted 19 February 2018 - 11:37 AM
It should go out after about 4-5 seconds in my experience. Have you got an oil pressure gauge at all?
Posted 19 February 2018 - 02:38 PM
No, just a light.
I've read on here that it can take up to a minute to get the pressure
Posted 19 February 2018 - 05:28 PM
Posted 19 February 2018 - 06:07 PM
Posted 19 February 2018 - 06:44 PM
Might get messy on an mpi... 😁Did you fill the oil filter with oil before fitting it?
Posted 19 February 2018 - 07:02 PM
Not if you're quick 😁Might get messy on an mpi...Did you fill the oil filter with oil before fitting it?
Posted 19 February 2018 - 07:25 PM
Posted 19 February 2018 - 08:14 PM
Posted 20 February 2018 - 11:45 AM
apparently its 1. 2. 3. 4. Going clockwise on the coil.
