hello.
one of my engines that was recently rebuild with a rebore, new pistons and rings, and a rebuild cylinder head with guides and valve seats have started using oil and it does not seem to be leaking out, I think cyilnder 3 uses it.
The question is then. Is there any way to test or deduce whether the oil is being sucked up past the piston rings or down the valve guide before I take it apart and check the guides?
thanks
