Minispares Inlet Abutment Plate Problem
Posted 19 February 2018 - 08:58 PM
Posted 19 February 2018 - 09:13 PM
id just grind it or get another Abutment plate see how that looks wonder if its off a 38 or other model
Posted 19 February 2018 - 09:22 PM
Posted 19 February 2018 - 09:32 PM
The carb is a Hif38
Posted 19 February 2018 - 09:55 PM
Posted 19 February 2018 - 10:17 PM
Posted 20 February 2018 - 12:08 AM
ive seen this problem quite a few times, as stated above use a file or grinder to relieve the metal and itll fit just fine
its because the abutment plate was designed to fit on the standard Austin rover manifolds, (alloy or cast iron) the inlet you have is an aftermarket one so it obviously just wasn't thought through very well when it was designed. iirc my dads mini has this setup and we ground that back to fit.
Posted 20 February 2018 - 10:24 AM
Posted 20 February 2018 - 10:03 PM
Posted 09 March 2018 - 08:38 PM
Posted 10 March 2018 - 01:41 PM
Could have just added another spacer with gaskets
Are you going to clean and service the carb ?
Edited by richmondclassicsnorthwales, 10 March 2018 - 01:42 PM.
Posted 10 March 2018 - 02:09 PM
Would be pretty tight to the bulkhead though and airbox is already tight. With just the one spacer
Posted 10 March 2018 - 09:11 PM
Yes will definitely clean and Sevice the carb. Might even have the abutment plate replated. Just trying to solve problems now so when I refit the engine everything bolts straight on .
