Mk1 Front Subby Tower Bolt Hole Threads
11 replies to this topic
#1 jchomme
jchomme
  • 99 posts
Posted 20 February 2018 - 02:59 PM
The 2 of 4  thread holes on my mk1 subframe are corroded, I was looking into using  EZ Lok inserts or welding  the hole closed and retap.  First option seems easier and less risky, but welding it up and tapping seems more permanent, but tapping might be a little difficult.
Any other possible solutions are welcome.
Also, could someone confirm what the thread pattern is for these mk1 subby tower bolts.  I have a cheapo gauge that just says 24.
thanks!
Edited by jchomme, 20 February 2018 - 03:00 PM.
#2 nicklouse
  • 17,945 posts
Posted 20 February 2018 - 03:28 PM
wet or dry?
guessing dry?
#3 Spider
  • 13,931 posts
Posted 20 February 2018 - 05:30 PM
Those are 3/8" UNF.
A suitable repair can be difficult, though looking at yours, I think they'd clean up quite OK.
If you were still concerned, a Helicoil type repair would be quite satisfactory.
#4 jchomme
jchomme
  • 99 posts
Posted 20 February 2018 - 05:52 PM
wet or dry?
guessing dry?
yeah, sorry dry.  I live in a 1960 Mini bubble and forget all the variations that ensued.
#5 jchomme
jchomme
  • 99 posts
Posted 20 February 2018 - 05:57 PM
Those are 3/8" UNF.
Thanks, one is slightly worse, so might only need to do one.  Was also looking into different thread locking compounds to help me sleep at night.
#6 jonny f
jonny f
  • 1,485 posts
  • Local Club: Boxhill Mini Club
Posted 20 February 2018 - 06:33 PM
run a tap down it. Looks like they will be fine to me.
#7 carbon
carbon
  • 2,590 posts
Posted 20 February 2018 - 08:02 PM
+1 for Moke Spider's suggestion about cleaning up the threads.
Would be careful if you do use a 3/8 UNF tap. Very easy to cross thread, which could really stuff the thread.
I suggest trying a good quality 3/8 UNF bolt lubricated with moly grease first, this may be all you need to clean up the threads.
#8 minimans
minimans
  • 411 posts
Posted 20 February 2018 - 08:49 PM
Run a thread chaser down them these will clean up the thread but not remove material, when refitting use a torque wrench don't over tighten them!!
#9 carbon
carbon
  • 2,590 posts
Posted 20 February 2018 - 08:58 PM
Minimans suggestion is right on the money.
More useful advice here: https://www.autoserv...-threads?Page=2
But not sure if you can easily get UNF thread chasers in the UK...
#10 jchomme
jchomme
  • 99 posts
Posted 21 February 2018 - 01:04 AM
thanks for the info all, I might try to make a chase with an old bolt.  Since the mounting point is quite meaty, an ez-lok should work.
#11 Spider
  • 13,931 posts
Posted 21 February 2018 - 02:08 AM
That's a good way to go.
You can make a poor man's thread chaser from a bolt, by filing a groove, longitudinally on the bolt, across the threads for a good length, that gives somewhere for all the crud to go as you're winding it in.
#12 jchomme
jchomme
  • 99 posts
Posted 28 February 2018 - 03:23 PM
Thanks all for the insight, I will try to do a post on refurbing my subframe and document my solutions.
