Item number 282852236190
How does this stack up as a replacement for my 998?
Any thoughts or comments to help this noobie would be appreciated
Edited by TobyM2018, 21 February 2018 - 03:38 AM.
Posted 21 February 2018 - 03:37 AM
Posted 21 February 2018 - 06:21 AM
Posted 21 February 2018 - 08:58 AM
Posted 21 February 2018 - 09:10 AM
I would take any engine bought off Ebay as a starting place for a rebuild.
450 will go a long way towards working on your engine.
look at it this way unless it comes with a guaranty or comes from a known engine builder, the most it is work is the surcharge value against a new rebuild engine.
Posted 21 February 2018 - 06:56 PM
Posted 21 February 2018 - 07:04 PM
It seems very expensive to me. Maybe I'm a bit out of touch, but I've never paid anything like that for an 'unknown'.
It's been left without manifolds on it and you can clearly see how the damp has got into the head. The fuel pump is smashed, which suggest careless handling and/or long term storage in less than ideal conditions.
There's better prospects out there, maybe put a wanted ad on this 'ere forum (best place to buy Minis and bits IMO!)
Posted 21 February 2018 - 07:09 PM
Posted 21 February 2018 - 09:20 PM
Left outside and obviously straight out of a metro as it still bears the mounts and thermostat cover - I find it a bit curious it's got two engine ID plates - one on the gearbox?? Running what I'd assume to be the credible number through Guessworks decoder reveals: Economy spec with an (originally but maybe in doubt) 3.1 diff.- I think it's been messed with though as head is a big valver (ex MG metro) ...and dizzy is a 59D4 - only fitted to the turbo if I remember rightly - so it may have been selectively upgraded... the presence of the oil cooler - although blanked off, makes me 99% convinced this engine has been messed with before...
Seems to be the 1275 ballpark price at the moment - but a refurb candidate - much worse have been brought back to life - just off the top of my head , strip / dip, rebore new pistons, crank grind , big end, main & cam bearings, new cam and duplex timing gear, new clutch kit a bucket load of sundries and gaskets as a DIY bill (bar machining and fitting cam bearings) no discernable change out of about 6 - 700 quid to spend - thats assuming that the gearbox is good or your existing box is up for a transplant (that'd be true of 90% of ebay engines.... don't know what's happened to him but there used to be a chap on there fond of his jetwasher and engine paint - instant "fully reconditioned" - so very much buyer beware - personally I always go & see...) The positive here is that this is complete - seller seems only to have removed the head to prove its seemingly unseized and bores resemble round...
You'd be able to reuse most ancilliaries off your current engine - even your HS4....but I'd budget new water & oil pumps, rad inc. bracket, dizzy, coil, hoses, engine mounts etc - some necessary and some that just need doing when you pull out your old lump...
Reconned short engines seem to be in the two and a half grand ballpark now... so options? There's a few ways of looking a this;
Buy it - recondition it yourself - and you'll know what's in it and have reassurance you've a good 'un (it's not hard by the way)
Buy it and farm out the whole job to the professionals - more expensive and lacking in personal satisfaction
Buy one "done" from ebay / private - be very very careful..... even more expensive
Buy one from a reputable builder - ouch
Down to you, your capabilities and budget.......
If it were me in need I'd just, let auction run it's course and if it doesn't sell contact seller and offer him 300 - that tactic has been massively successful for me over the years!
Edited by wile e coyote, 21 February 2018 - 09:48 PM.
Posted 21 February 2018 - 09:22 PM
An engine you can hear and see running is your best bet. If that's not possible, you need to assess it the best you can. Dip the oil (if it's still in it). Is it fresh, black, brown or emulsified?
Remove the oil filler cap. What's it like inside? If it's showing nasty black deposits that scrape off and look burnt, the engine hasn't been serviced when it should have and is probably very close to needing a full rebuild. Is there sludge in the rocker cover?
Look at the outside. Is the block very oily? Neglected engines block their breathers with the sludge described above and then leak oil out of every gasket and seal.
Regarding storage, I always plug every place the damp can get in. That means cloth stuffed into the carb (if fitted) or into the exhaust and inlet ports. Missing spark plugs are not a good sign either.
As I said above, I may be a bit out of touch nowadays, but for £450, I'd want a good used engine I could fit with only a little 'freshen up' work. It wasn't that long ago that we used to pick up good low milers for £50!!
Posted 22 February 2018 - 01:48 AM
Posted 22 February 2018 - 08:59 AM
it all comes down to why you are buying a engine. to use as is or as a base for a new build
that one you may have noted had a oil to water oil cooler so may have been an MG version (but IIRC others had it) and it was an easy add on.
but with the one in the first post points to note. no oil in it (pot joints no present) lots of unsealed openings. only fit for a strip and rebuild. about 250 too much in my eyes.
be aware there are a few well known engine scams on ebay and other sites. a few hare listed on here look in the feed back section. or just ask.
