Hi all,
Here is a video of my MPI trying to start.
Sorry about the shakes, my arm was resting on the door frame.
Any help appreciated, I need to get this thing going.
Thanks.
Pete.
Posted 22 February 2018 - 09:31 AM
Hi all,
Thanks.
Pete.
Posted 22 February 2018 - 10:07 AM
Posted 22 February 2018 - 10:11 AM
Nothing is squashed, fule is going through the orange tube, but nothing in the green tube (return to tank)
The filter looks good from the outside might change it so see
The pump is as old as the car, 20 years.
Posted 22 February 2018 - 10:24 AM
Posted 22 February 2018 - 10:27 AM
the car has either done 47000 kms or 147000 kms. It's had a rebore so i reckon 147000 kms
Yes all pipes on and none are split.
Posted 22 February 2018 - 12:06 PM
Are you sure you are getting Fuel Pumping?
Posted 22 February 2018 - 01:13 PM
There is definately fuel coming from the injectors, they are wet.
Tuesday, only one of the injectors was wet, the other one was blocked closed. That has now been freed off and is also now wet, so fuel is getting there, but I don't know if it is under enough pressure.
The green return pipe to the fuel tank is dry, i don't know if that means anything or not, when the ignition is on, the pump only primes for about 2 seconds max. Not enough in my view to get the pressure up to 3 bar.
Posted 22 February 2018 - 01:33 PM
Posted 22 February 2018 - 01:34 PM
Posted 22 February 2018 - 01:53 PM
Yes spark is fine, tested on all four leads, and all four plugs.
The injector was stuck shut because it hadn't been used for about 4 years. Not dirty or contaminated etc. They both open when powered and close when not powered. When open i can blow through them, when closed i can not.
Posted 22 February 2018 - 02:13 PM
Posted 22 February 2018 - 02:19 PM
Yes it does, and when i turn it off
Posted 22 February 2018 - 02:47 PM
Posted 22 February 2018 - 03:00 PM
I'm with you on this, i think it's a fueling problem too. I don't think there is enough pressure.
I have checked and double checked all plugs on all sensors yes.
I have no idea if a faulty sensor would do this.
I always thought a crank sensor either worked or didn't work i never thought they could kind of work but not correctly, i might look into that too.
Posted 22 February 2018 - 03:07 PM
Re watching the video again I see a backfire during cranking. There are other backfires in the video but always at the end of it's attempt to run.
A backfire during cranking would mean what ? ignition timing out ?
How does the ignition timing work on an MPI ???
