Rear End
Posted 22 February 2018 - 06:39 PM
The boot area is one thickness of steel then were the boot hinge panel and rear valance meet its 3 thick??
Around the subframe mounts is it boot floor and a stiffened underneath then close out panels or does the close out panel have a plate as well making that 3 thick.
Mine's that corroded and patched I can't tell!!!!!
Posted 22 February 2018 - 07:36 PM
Yep, 3 thick
On the top should be the stiffener bracket that attaches to the boot floor and arch, then the boot floor, then a strengthener panel then the rear valance closers
Posted 22 February 2018 - 07:39 PM
At the very rear you have a 3 layer sandwich. From top to bottom it goes;
Rear Panel
Boot Floor
Rear Valance
I was wondering myself about the subframe mount areas. I fitted a new heritage boot floor which came with a strengthening plate already welded to it. I believe you can buy the valance closing panel either with or without this strengthening panel attached, depending on whether you already have one or not. I stand to be corrected by someone more knowledgeable though.
Posted 22 February 2018 - 07:49 PM
Sorry if repeating myself just need it clear in my head!!
Posted 22 February 2018 - 07:52 PM
I have to say i have fitted two Heritage boot floors and neither of them came with any reinforcement on the subframe mounts. The Heritage valance closeout is multiple layers.
Posted 22 February 2018 - 08:05 PM
Edited by Swift_General, 22 February 2018 - 08:05 PM.
Posted 22 February 2018 - 08:10 PM
Bad info on my part then. I bought mine through M-Machine so it must be something they add to the Heritage boot floors prior to dispatch. You can see them here.
Thanks for that. The bracket from arch to boot floor, does that have a plate on it or is it just shaped. I'm guessing plate making that area 3 thick around sub mount.
Its a shaped piece with the 2 holes in for the subframes bolts to go through.
Edited by SamG, 22 February 2018 - 08:11 PM.
Posted 22 February 2018 - 09:11 PM
Posted 22 February 2018 - 09:15 PM
!.2mm. That is what i added to my lads car. Then i welded the multi layer valance closeout to that. Overkill but that was a first time effort on his car.
Posted 22 February 2018 - 09:25 PM
Ok thanks again.
Looks like a busy weekend for me!!!
Posted 02 March 2018 - 08:53 PM
Posted 02 March 2018 - 08:56 PM
Just another thing......my rear floor repair panel I'm making, are the flanges to weld it up to arches etch, are they folded down ( as in underneath) or up as normal.
Folded down.
Posted 02 March 2018 - 09:03 PM
