Edited by rustyrood, 22 February 2018 - 08:15 PM.
Posted 22 February 2018 - 08:13 PM
Posted 22 February 2018 - 08:58 PM
..should go to to vacuum take off on the carburettor - normally a thin plastic tube connects the two together (it's possible the 'cut' section of hose is being used as a fitting for the plastic tube)
..is that a bit of thin plastic tube at the bottom of the picture ? or a bit of wiring ?
without it you'll be losing ignition timing advance when the engine is under load
Edited by KTS, 22 February 2018 - 09:00 PM.
Posted 22 February 2018 - 10:25 PM
you need a stiff plastic hose not a rubber hose as this will collapse under vacuum https://www.holden.c...s&pCode=030.015
Posted 23 February 2018 - 05:33 PM
Pipe marked in red/pink ... where does this go as it could have pulled out. The other end should be on the inlet/carb.
vacuumtube.jpeg 44.19K 1 downloads
