New Built 1283 Poor Running
Posted 24 February 2018 - 01:20 PM
Noticed the other day it was taking longer to warm up, lots of spluttering at higher revs for a few miles. Thought that was all it was until today. Started her up, full choke then back to half choke which is my normal routine. Went to drive off and engine just died and would tickover. Can start and rev it it but lots of flat spots almost as if dizzy had shifted round and timing was off.
Checked that and no movement from dizzy, diconnected fuel line and fuel pumping fine. Thought Id try to reset timing so I wound idle right up but couldnt get car to tick over for long enough!
It definitely feels and sounds like a timing issue. Brand new coil, dizzy, alternator, refurb card, new fuel pump so cant understand what could suddenly make the car run so poorly.
Any ideas of what else I could check??
Posted 24 February 2018 - 01:27 PM
Oil in the dashpot??
Posted 24 February 2018 - 01:29 PM
Posted 24 February 2018 - 01:35 PM
Posted 24 February 2018 - 01:36 PM
Just thinking about the basics really, so plugs leads, rotor cap, arm etc etc.
Check your tappets, make sure nothing has closed up. If there is oil there don't add anymore on the dashpot. Too much oil can cause problems.
Posted 24 February 2018 - 02:04 PM
Posted 24 February 2018 - 02:34 PM
Posted 24 February 2018 - 03:22 PM
Set clearances to 0.015 which seems about right according to my engine spec
No change but did notice when taking plugs out that they are very very coked up.
Getting a pops and bags now when revving car, wont idle at all
Stumped!
Posted 24 February 2018 - 03:53 PM
Posted 24 February 2018 - 04:27 PM
Posted 24 February 2018 - 04:46 PM
I have had duff plugs in the past.
Posted 24 February 2018 - 05:03 PM
That should say can’t see level at top!
Sounds like the fuel pump and / fuel line / fuel filter might be worth checking.
Also, before getting too adventurous using spanners with your new engine, I'd suggest referring back to the company who did it so as you don't void your warranty.
Posted 24 February 2018 - 07:43 PM
Wild card. How old is the exhaust, and any chance of the silencer being blocked?
I have had this happen long time ago on Metro. Would idle OK but no power.
Posted 24 February 2018 - 08:23 PM
Just a thought, but you have put fresh fuel in it haven't you? If you've not used it for ages the fuel will have gone off.
Phil.
