Many Many Things
9 replies to this topic
#1 Will16
Will16
    Wants a custom member title
  • 1,090 posts
Posted 24 February 2018 - 05:00 PM
All gone now!
Had a good garage clear out today, come to the fact that I've got alot of stuff that realistically I'm not ever going to use. I'm well aware that alot of this stuff may be junk, but as the saying goes one mans trash is another treasure  :gimme:
If you see any bits your welcome to them to collect from Abingdon, Oxfordshire, I can post, at your cost too
Shocks, grubby but useable
GONE Wipac spot light
GONE Raydot yellow spot, pitted on back
GONE 1993 gear selector box no rollpins
Interior gear gaiter bases x2
GONE New later rear subframe polybushes
Bottom arm pins
Single seat bracket
Rear subframe exhaust mounts x2
Fresh air vent blanks x2
GONE New locking fuel cap
GONE Drivers mirror Rover black
GONE Old type fuse box mk3
GONE Random copper pipe, think its part of the rear brake?
GONE Cosmic bonnet lock with key
Mk3 flappy air filter
Wiper motor (not complete)
GONE MK3 washer motor
GONE MK3 washer bottle brackets and bottle fittings (Do have bottle but leaks)
Wiper motor straps x2 (rubber block GONE)
GONE Single line clutch master (Used for 3000 miles, then did an engine conversion)
GONE Alloy Speedwell gear knob
GONE Old school Wiper speed switch
Condensor and rotor arm
Mk3 subframe to front panel shims
GONE Bonnet release stuff
GONE Clear side repeaters
Mk1/2/3 subframe bolt locking plates
GONE Smiths temp gauge (Not sure if it works)
GONE AA badge
GONE Trumpet for carb
Steering cowl with key hole
Seat bracketS x2
998 rad support
GONE Indicator rubbers x4
GONE Fresh air pipe
GONE New late handbrake cable
Wiper motor plastic cover
GONE Choke cable x3
Subby tower bolts
Number plate light wiring
GONE Rover flame red touch up pen set
GONE City hubcap
Headlight bucket and rubbers
GONE Random copper pipe (Again think rear brakes?)
GONE Dash panel with old choke cable and heater cable (think mk2/3)
Wooden Interior pieces, all of these have damage
Standard rear trumpets, think a couple have been cut down to lower the car and washer bottle with intergrated pump
MK3 drivers seat, back is knackered and taped up
Exhausts (From right to left)
ON HOLD Think stainless back box with rolled tip and link pipe. Whats left of the y piece is stuck lol
RC40 rear box with a larger tip welded on, quite in your face, has small hole but doesnt blow and passed mot
RC40 mid box side exit. Now if your handy with a welder this is a great sounding exhaust, with just that small box in the system, doesnt have to be side exit you could cut it up. Also have the link pipe and y piece. Pretty sure I've still got the LCB for it, but its got a crack
40415456002_bf7ac46f7d_c.jpgUntitled by Will Giddings, on Flickr
25588225517_9a32927519_c.jpgUntitled by Will Giddings, on Flickr
Edited by Will16, 14 March 2018 - 08:27 PM.
#2 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 24 February 2018 - 05:55 PM
i would be interested in coming and picking this all up
#3 paul50
paul50
  • 86 posts
Posted 24 February 2018 - 07:26 PM
Do you still have the manual
#4 Rocket.
Rocket.
  • 1,441 posts
Posted 24 February 2018 - 07:59 PM
Ill take the gear selector housing bits if youll post them?
PM me the cost
#5 PetePinnington
PetePinnington
    Formally known as PPinno
  • 367 posts
Posted 24 February 2018 - 11:02 PM
I'll take the smiths gauge and the choke cables if they haven't already! Let me know the damage on postage
Pete
#6 Mat
Mat
  • 254 posts
Posted 25 February 2018 - 08:42 AM
Could I have the washer bottle brackets, leaky mk3 washer bottle and bonnet release bits please? Postage for me please, let me know how much! Thanks!
#7 Xinarin13
Xinarin13
  • 81 posts
Posted 25 February 2018 - 02:54 PM
I am interested in the 2 wooden handles
#8 bluemini1979
bluemini1979
  • 619 posts
  • Local Club: Colchester Mini Club
Posted 14 March 2018 - 08:01 PM
How much to post the 2 seat brackets and the steering column cowling?
#9 Will16
Will16
  • 1,090 posts
Posted 14 March 2018 - 08:26 PM
Sorry, the rest of this was binned  :wacko:
#10 bluemini1979
bluemini1979
  • 619 posts
Posted 14 March 2018 - 10:26 PM
Ok thanks for replying :)
