Lots Of Simple Questions At Once
261 replies to this topic
#136 Tonylamb
Tonylamb
  • 360 posts
Posted 05 April 2019 - 09:01 PM
Clutch release bearing? It does rattle when you are going along but it's so loud it's hard to tell if it's the same.
#137 nicklouse
  • 19,057 posts
Posted 05 April 2019 - 09:11 PM
then i would be seriously looking at the release bearing as that rattle if the idler gear will shut up under load.
the shutting up with the clutch pedal depressed is normally the release bearing but also will shut up the gears as you are removing the drive to them.
you said earlier that it is not the release bearing why are you thinking this
#138 Tonylamb
Tonylamb
  • 360 posts
Posted 07 April 2019 - 09:20 AM
I don't know why I said that to be honest. I always imagined a release bearing to whine like a wheel bearing does. Plus I've had a dodgy release bearing on a car before. This noise isn't like a bearing sound if that makes sense. Its more of a clattering rattling sound. Almost like something in the clutch or gear box is loose and is clipping something as it rotates. I was thinking that perhaps a bit of the clutch was sticking out and tapping the clutch housing or something. perhaps a loose bolt. clutch because it stops when you depress the pedal. Also you can hear the release bearing whine when you depress the clutch but the clattering sound stops??? But as you say depressing the clutch also disengages the gears so it could be something in there? I spoke to my engine builder and he checked all the clearances and says that when he ran the engine it didn't make that noise. So its presumably something that has happened since the engine was loaded up in the car. All a bit of a mystery and as I spent a good amount of hard earned on it I don't see any choice but to take it out and take a look in the clutch housing for starters.
#139 Steve220
Steve220
  • 5,142 posts
  • Local Club: BMC
Posted 07 April 2019 - 09:28 AM
Doesn't sound release bearing to me, theyre not exactly the largest thing in the world. If its your primary gear, you'll have a large pool of oil being left under the O/S of the car. My guess is idler, which unfortunately (for an easier solution) is engine out.
#140 nicklouse
  • 19,057 posts
Posted 07 April 2019 - 12:12 PM
the release can make a similar noise. but it is as i said before more like the idler.
next thing to do is raise the revs a bit and see if it smother out the revs and shuts up the rattle. and get someone to hands on look.
#141 Steve220
Steve220
  • 5,142 posts
  • Local Club: BMC
Posted 07 April 2019 - 01:18 PM
Also try getting a long handled screwdriver and put the tip on different places and the handle on your ear, you'll hear it prominently from the area its making the rattling.
#142 Tonylamb
Tonylamb
  • 360 posts
Posted 07 April 2019 - 07:33 PM
revving the engine doesn't seem to make any real difference to the rattle. Its still there. I'll try a long screwdriver for listening but its definately coming from the clutch end of the engine. All very odd. I'm off on a business trip but will take the engine out when I get back. I'll let everyone know what happens.
#143 Tonylamb
Tonylamb
  • 360 posts
Posted 07 April 2019 - 08:06 PM
So I tried the screwdriver to listen but it's not overly obvious where the noise is directly coming from. I've tried to take another video. Ignore the end forgot to turn the video off LOL. There is a bearing type noise that goes away with the clutch depressed. Also the rattle does seem to go somewhat as you put a few revs on. Still think the engine will have to come out. But any more thoughts appreciated. Frankly it's got to be either the idler gear or the clutch release bearing. If it's the idler I dont want it to wreck the bearing housing.
#144 Tonylamb
Tonylamb
  • 360 posts
Posted 07 April 2019 - 08:07 PM
Forgot the link
https://youtu.be/8cH-bpJ9yeA
#145 imack
imack
  • 2,381 posts
Posted 07 April 2019 - 08:33 PM
I wouldn't worry too much about the whirring bearing type noise, I think you'll find it's just the noise of the straight cut gear set turning when the clutch is engaged. The release bearing shouldn't be turning when the clutch is engaged if the clearance at the release arm is correct.
My straight cut box makes exactly the same whirring noise until you disengage the clutch.
The rattle sounds like idler gear to me though.
#146 Tonylamb
Tonylamb
  • 360 posts
Posted 19 April 2019 - 08:18 PM
So whilst I think the engine does have to come out I thought I would readjust the clutch clearances and see if it made a difference to the dreaded rattle. It does, its much worse LOL. I took a quick video. the rattle does seem to stop when the revs rise and it goes away completely when the clutch is depressed. its most odd. As you can probably hear it doesn't sound like a bearing more like something "Clattering" or "Chattering". And it would seem to be definately the clutch end of the car. It also seems to have a bearing noise when driving along which I suspect is a wheel bearing. Don't know why because they are both new???
https://youtu.be/WxdpSGvQE4g
#147 imack
imack
  • 2,381 posts
Posted 19 April 2019 - 09:31 PM
What cam are you running and what idle speed? Idle sounds quite low.
#148 Tonylamb
Tonylamb
  • 360 posts
Posted 20 April 2019 - 10:06 PM
It's just a fast road cam and the idle is a about 1100 there was a bit of choke in the video.
#149 Tonylamb
Tonylamb
  • 360 posts
Posted 02 May 2019 - 07:58 AM
I've got most of the ancillary bits off the engine water drained etc. Just need to Jack up remove drive shafts exhaust etc. I did notice that the flywheel teeth have some very minor damage from the starter motor teeth. I dont suppose the starter could be the source of the rattle. But then why would it stop with the clutch depressed. The fly wheel cant move back and forth?
#150 johnR
johnR
  • 2,322 posts
Posted 02 May 2019 - 09:43 AM
It could if the crank thrusts are worn?
Edited by johnR, 02 May 2019 - 09:43 AM.
