Lots Of Simple Questions At Once
#196
Posted 17 October 2019 - 07:02 PM
#197
Posted 22 October 2019 - 12:27 PM
#198
Posted 22 October 2019 - 01:56 PM
#199
Posted 22 October 2019 - 02:06 PM
it is a bolt. generally the engine mount bracket needs one of the long bolts (upper) removing to get a socket on it. a big spanner may fit.
you should remove the starter and lock the flywheel with a suitable tool.
#200
Posted 22 October 2019 - 04:54 PM
#201
Posted 26 October 2019 - 07:19 PM
Posted 26 October 2019 - 07:47 PM
Yep you will need to remove the engine mount with that crank damper/pulley.
damper “just” pulls off. Some are harder than others.
#203
Posted 28 October 2019 - 07:00 PM
#204
Posted 28 October 2019 - 09:45 PM
Yes there should be a flinger yes care should be taken with the alignment or you may have a leak.
#205
Posted 29 October 2019 - 08:15 AM
#206
Posted 29 October 2019 - 08:18 AM
yes there should be but the material does not seem to be as good now so most people use a medium thread lock instead.
PS have a very close look at the key way as the do crack through from the key way to the seal surface side.
Edited by nicklouse, 29 October 2019 - 08:19 AM.
#207
Posted 21 November 2019 - 10:23 PM
#208
Posted 23 November 2019 - 05:20 PM
one other item i've had some issues with the starter switch. sometimes it works sometimes nothing. Bonnet up and wiggle the solenoid and it works. the wires are all tight. Could it be a faulty solenoid. i notice its a bit loose on the wing. Does the solenoid need to be well earthed? could be that.
#209
Posted 23 November 2019 - 09:00 PM
#210
Posted 23 November 2019 - 09:15 PM
