Lots Of Simple Questions At Once
#106
Posted 06 February 2019 - 05:53 PM
#107
Posted 06 February 2019 - 10:34 PM
If using these on 10" wheels with Hilos you may have to cut 3/4" off the end of the centre threaded bolt of the old type Hilo with a circlip as it will bottom out on the cone spring face and the car will sit high, for extremely lowered cars the hilo face will also need machining a few mm.
I'm not entirely sure what the centre threaded bolt is? Can anyone show me exactly what this means perhaps with a diagram?
#108
Posted 07 February 2019 - 07:56 AM
Did you fit hilos for adjustable ride height? To be honest, if you've bought the hilos fairly recently I doubt they'd be the old type.
#109
Posted 07 February 2019 - 08:07 AM
#110
Posted 08 February 2019 - 10:19 AM
Thinking it sounds like they need taking out and turning down about 10 or 12mm
The leverage is 3:1
You can take material off both the seat part and at the ball end
#111
Posted 09 February 2019 - 08:09 AM
#112
Posted 09 February 2019 - 06:09 PM
#113
Posted 09 February 2019 - 08:22 PM
#114
Posted 09 February 2019 - 10:02 PM
#115
Posted 09 February 2019 - 10:40 PM
#116
Posted 11 February 2019 - 07:53 AM
Good to see you got the hilo problem resolved. So the new genuine hilo you bought from minispares had the circlip? In their description, I thought the circlip was an older type that has been superseded. I'll take note as I have some to fit to mine with 10s but its all boxed up waiting to be fitted.
#117
Posted 11 February 2019 - 09:49 AM
CCK historic should be able to get your suspension set up. They are used to working on classic minis and many other classic cars and arent too far from Tunbridge wells also have a rolling road for getting carbs etc sorted and setup:
I cant say I have used them but I was looking to take my car there to get setup once its on the road
#118
Posted 11 February 2019 - 11:55 AM
Don't know if it's relevent, but the suspension can take a fair while to settle after you've fitted new parts. Wait until you've driven it for a bit before attempting a final setup. The factory figure is about 1 degree of positive camper.
Oil pressure might be down to the relief valve sticking.
#119
Posted 12 February 2019 - 10:26 PM
#120
Posted 24 February 2019 - 06:39 PM
