Cooper Mpi
Best Answer Sprocket , 25 February 2018 - 11:49 PM
Hi all
Problems with my cooper 1.3i mpi
I changed the plugs and ht leads and all was mint I had her ticking over and she ran out of petty put some in and went to the garage and filled her up and she wouldn't start after about half an hour  she started up and I took her out and went about 10 miles all was mint pull over and when I tried to start to start her again she wouldn't start after about 1/2 hour she started again and no problems , splutter once one the way home started her this morning ticking over mint
any thoughts
I responded to your identical topic in the main technical section, have you not seen that? Go to the full post
4 replies to this topic
#1 Jay136
Jay136
    Starting My Mini Up
  • Validating
  • 2 posts
Posted 25 February 2018 - 05:33 PM
Hi all
any thoughts
#2 MiniJosh92
MiniJosh92
  • 1,690 posts
Posted 25 February 2018 - 06:18 PM
If it was fine before you did the plugs and leads I would start by just checking all possible connections and that you fitted the correct parts. If not could possibly be the crank sensor or coil pack.
#3 Milton
Milton
  • 54 posts
  • Local Club: what no brakes
Posted 25 February 2018 - 06:38 PM
If you ran out of petrol it is possible you sucked sediment from the bottom of the tank into the fuel system. Personally I would change the fuel filter.
#4 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 25 February 2018 - 11:45 PM
where does the fuel pump draw fuel from?....... The bottom of the tank, whether full half full or empty.
I have yet to see a fuel tank with sediment in it.
This is clearly another problem as it wouldn't just get better if the filters were blocked...........
#5 Sprocket
Sprocket
  • 7,266 posts
Posted 25 February 2018 - 11:49 PM   Best Answer
Hi all
any thoughts
