Hinges, Geniune Vs Repro/pattern
13 replies to this topic
#1 mark197
mark197
  • 58 posts
Posted 25 February 2018 - 08:43 PM
What’s the difference between genuine hinges and the repro pattern parts?
I have recently started a project and the hinges I have are very poor and I want to avoid using them. I also want to replace with something better than the ones I have taken off.
If I get second hand and replace the roll pins will this remove any play in the hinges?
Thanks in advance!
#2 FlyingScot
FlyingScot
  • 2,660 posts
Posted 25 February 2018 - 08:57 PM
Mk1 or Mk3 hinges?
FS
#3 mark197
mark197
  • 58 posts
Posted 25 February 2018 - 10:17 PM
MK3 internal
#4 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 26 February 2018 - 07:28 AM
copy ones are rubbish whats wrong with yours?
#5 DomCr250
DomCr250
  • 667 posts
  • Local Club: 16V mini club
Posted 26 February 2018 - 10:53 AM
Normally the worst thing that happens to mk3 onwards hinges is the studs break off when you remove them..it's an easy job to grind down the existing weld and put a new stud in.
#6 mark197
mark197
  • 58 posts
Posted 26 February 2018 - 01:02 PM
It's a bit of a long story, but I have a Domino HT that I am restoring. The hinges have been hacked in an attempt to fit badly hung doors. Every hinge is loose at the pivot pin and I cant be sure if the pins are worn or they have been drilled to remove the pins in the past...
I'd rather start from good second hand or new parts and hang the doors right from the off.
My thoughts are if I hang the doors to the new hinges and get the gaps right and they don't catch anywhere when being opened and closed, I shouldn't have any problems for the foreseeable future.
#7 AndyR
AndyR
  • 453 posts
  • Local Club: None
Posted 26 February 2018 - 04:28 PM
In the middle price wise between the genuine and the copies, the DSN classics alloy hinges are lovely quality and save a little weight.
Andy
#8 mark197
mark197
  • 58 posts
Posted 26 February 2018 - 05:05 PM
You have to be on a serious diet to warrant buying lightweight hinges... They do look like a good product though from the pictures I've found.
#9 AndyR
AndyR
  • 453 posts
  • Local Club: None
Posted 26 February 2018 - 05:19 PM
I didnt buy them for the weight saving, but i must say it didnt hurt in persuading my bank card out my wallet.  Much like yourself, mine had been fiddles with in the past, welded a few times by previous owners (with different threads) and the pins were a little sloppy, so i went for them as they were cheaper than originals....... and i do like shiny things!
#10 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 26 February 2018 - 06:03 PM
message me, i can send u good hinges
#11 mark197
mark197
  • 58 posts
Posted 27 February 2018 - 11:23 AM
It does help if you can find a persuasion.
#12 mark197
mark197
  • 58 posts
Thanks for the reply. Pm'd
#13 MikeRotherham
MikeRotherham
  • 939 posts
Posted 27 February 2018 - 06:58 PM
Don't know if these hinges may be any use to you for one side of your car, perhaps you've already seen this?
https://www.ebay.co....353.m1438.l2649
#14 mark197
mark197
  • 58 posts
Posted 01 March 2018 - 08:21 AM
Thanks for the link. I had seen them. Typically I have started with the passenger side door so need that side first!
minidaves has sent me some hinges which should be more than adequate. hopefully I will receive them at the weekend so I can get the doors somewhere near hung!
