Rev Counter
Posted 25 February 2018 - 09:14 PM
I've also noticed the interior light, hazards and indicators don't work, but I have just replaced the hazard switch which I think is the issue on that one.
Just worried about my dash!
Any help is appreciated
Paul
Posted 27 February 2018 - 01:12 PM
Check your fuse box.Look at the fuses and the clips-are they nice and bright? If not, it might be an idea to replace the fuse box.Use decent fuses (i.e. Minispares)/Somerfords)
I seem to remember the Tacho and Heater are on the same fuse-it happened to me a few years ago
Hazard and indicators have line fuses, which should be behind the airbox on the bulkhead If its not them it may be the relays.(The M6killed my indicator relay a few days ago)
If the wiper motor will not park, you need a new Park switch.
The speedo sounds like the drive might be binding, but check it is fully engaged with the instrument panel first
Interior lights are probably the door switches not working, but move the switch on the light to check you have power.If not, its probably another fuse.I don't have my Haynes in front of me, so I don't know which one)
I( assume you have a Haynes?)
Good luck, particularly in this weather; I have been outside repairing damage sustained to my RSP on the M6 at Knutsford-there are a lot of BIG potholes in the northbound middle lane.
Posted 28 February 2018 - 08:27 AM
Posted 28 February 2018 - 12:44 PM
Good luck-hope you have a garage.
