Does This Seem Correct
Posted 25 February 2018 - 11:13 PM
Posted 25 February 2018 - 11:34 PM
no cup washers?
the nut should bottom out.
Posted 25 February 2018 - 11:42 PM
Posted 25 February 2018 - 11:44 PM
Posted 26 February 2018 - 01:23 AM
stainless nylocks? i hope not. and do you have the tiebar to bottom arm bolt in stainless as well? (does not look like it has enough shoulder on it).
Posted 26 February 2018 - 08:12 AM
Are those polly bushes both sides? I thought that was considered bad practice and that polly on the front and rubber on the rear was the best setup for tie bars.
Posted 26 February 2018 - 08:38 AM
Thats what ive done to mine, it mentions on minispares site when you look at eth bushes
Posted 26 February 2018 - 08:51 AM
Your subframe is shinier than my car's exterior paint job!
I too, have one poly and one rubber bush on each side. The problem here, is getting a rubber bush that lasts more than 3 months...
Posted 26 February 2018 - 09:54 AM
Posted 26 February 2018 - 10:11 AM
The theory goes that poly both sides of the subframe ear does not allow enough compliance during full suspension movement and may flex and ultimately crack the subframe ear.
A polly bush at the front keeps suspension alignment when breaking (puling the tie rod backwards into the subframe) and a rubber bush at the rear allows enough compliance for the ear.
I have the polly/rubber combination which seems to work well.
Posted 26 February 2018 - 10:16 AM
Posted 26 February 2018 - 03:14 PM
Posted 26 February 2018 - 03:31 PM
The rubber bushes I've had from Minispares have lasted 5 years so far. Though rubber from any supplier seems to be a hit and miss affair.
Posted 26 February 2018 - 09:53 PM
no cup washers?
Even with one poly I torque to 52Nm as per Rover spec. never any problems
Posted 26 February 2018 - 09:58 PM
It is a good idea to weld a triangular support plate, made from 4 mm thick steel, onto each front ear to prevent any risk of fatigue failure of the welding on the original 'ear'.
Remember, these sub-frames are old and have already done a lot of work.
