After draining/cleaning rad/cooling system please. Can I use pink?
Jonathan
Posted 28 February 2018 - 05:03 PM
Jonathan
Posted 28 February 2018 - 05:38 PM
Depends on your radiator. Probably not, most pink coolant is for alloy rads.
Posted 28 February 2018 - 05:58 PM
Dude, this is a subject of much debate. I asked the same question a few months back. Please review the link below. I was going to use pink but went with blue.
http://www.theminifo...radiator-fluid/
Posted 28 February 2018 - 06:42 PM
Posted 28 February 2018 - 06:54 PM
Stick with blue or green, pink supposedly corrodes the solder in brass rads and heater matrix.
Blue needs changing less frequently than green.
which is why it was speced for the MPIs with the alloy rads.
Mini Technical Sections →
Problems, Questions and Technical →
Piston Rings - A-Series 998 Engine - Help RequiredStarted by WanaGo , 18 Apr 2024 engine |
Exhaust Choice 45Dcoe - Rc40?Started by lachlan1275gt , 13 Apr 2024 engine |
1071 Main Bearing Caps.Started by 246jaenick , 02 Apr 2024 engine |
Misfire - Ignition Fault Or Fuel Problem?Started by derekaka2sheds , 01 Apr 2024 electrical, engine |
Which Rocker ArmsStarted by mark the diver , 30 Mar 2024 engine |
