Second Opinion On Inner Wings
Posted 04 March 2018 - 04:55 PM
Are these difficult to line up?
WP_20180304_16_18_06_Pro.jpg 60.8K 1 downloads WP_20180304_16_25_06_Pro.jpg 56.07K 2 downloads
On the right hand side, I'm planning to just replace the front half of the inner wing as the rest seems fairly solid to me. There is a bit of pitting near the back at the top but this s nowhere near going through and is rotting from the side where the pitting is visible from. The lower windscreen surround corner has rotted away in this area and is currently 80% filler. So, just wondering if it will be easier to cut the entire wing out and replace in the same way as the left wing, which may help access the corner of the windscreen surround?
WP_20180304_16_24_44_Pro.jpg 51.12K 2 downloads WP_20180304_16_18_32_Pro.jpg 52.85K 2 downloads WP_20180304_16_18_42_Pro.jpg 55.84K 0 downloads WP_20180304_16_24_44_Pro.jpg 51.12K 2 downloads
Posted 04 March 2018 - 04:58 PM
Posted 04 March 2018 - 06:50 PM
full panel and easy to line up, screw all the front together before welding and fit doors then you know you have it right
Posted 05 March 2018 - 08:37 AM
See this thread - http://www.theminifo...anel-stiffener/
If you're going to replace the whole panel I would advise against the fully built up item, it's more trouble than it's worth and you'll probably end up dismantling some or all of the parts to make it fit.
Posted 05 March 2018 - 10:06 PM
I'll order separate panels.
Posted 06 March 2018 - 09:51 AM
I was hoping the combined panels would be a pretty good fit and save some time.
That was my assumption too but unfortunately it wasn't to be, and it seems I'm not alone....
